- To: Gyesik Lee <gslee AT ropas.snu.ac.kr>
- Cc: coq-club AT inria.fr
- Subject: Re: [Coq-Club] Indexed Types Pattern Matching Problem
- Date: Mon, 22 Mar 2010 19:15:48 +0200
- Disposition-notification-to: Roman Beslik <beroal AT ukr.net>
On 22.03.10 16:35, Gyesik Lee wrote:
Many thanks Roman."inversion x0" does "pattern matching". I think that it fails because "subst b" stands before "inversion x0" (see another proof below). "inversion H. subst b." changes "x0" to something different. There are different variables "x0 : Interpret RT b" and "x1 : Interpret RT Rec" in the proof term.
You gave me the right answer what I wanted to know.
Doing "pattern matching" again was the key point, I think, to overcome
Coq's restriction, wasn't it?
Now when I look at the proof term created by Coq, it is really hugeYou can move that pattern matching to separate theorems.
because of pattern matching caused by "discriminate" tactic.
I am wondering if there is a way to simplify it.
Definition to_T (a : Rep) (x : Interpret RT a) : (a = RT) -> T.
refine (fix to_T (a : Rep) (x : Interpret RT a) {struct x}: (a = RT) -> T :=
match x with
| inl a b _ => _
| inr a b x0 => _
| rec _ => _
| const _ _ => _
end
); intros; try discriminate.
inversion H. subst a0. inversion i. exact (A X).
(* second case: [r = Rec] *)
inversion x0.
subst b; try discriminate.
refine (to_T _ X (refl_equal _)).
Defined.
Best regards,
Roman Beslik.
- [Coq-Club] Indexed Types Pattern Matching Problem, Gyesik Lee
- Re: [Coq-Club] Indexed Types Pattern Matching Problem,
Roman Beslik
Gyesik Lee
Roman Beslik
Gyesik Lee
Roman Beslik
- Message not available
- Re: [Coq-Club] Indexed Types Pattern Matching Problem, Roman Beslik
- Re: [Coq-Club] Indexed Types Pattern Matching Problem, Gyesik Lee
Roman Beslik
Gyesik Lee
Roman Beslik
Gyesik Lee
Roman Beslik
- Re: [Coq-Club] Indexed Types Pattern Matching Problem, Adam Chlipala
