- To: "Catalin Hritcu" <catalin.hritcu AT gmail.com>, "Ruddy Hahn" <ruddy.hahn AT gmail.com>
- Cc: coq-club AT inria.fr
- Subject: Re: [Coq-Club] Lists without repetition of occurrences
- Date: Wed, 24 Mar 2010 20:14:41 +0100
- Organization: ProVal
Le Wed, 24 Mar 2010 19:29:50 +0100, Catalin Hritcu <catalin.hritcu AT gmail.com> a écrit:
Hi Ruddy,
Another solution would be to use normal lists, but to carry separate
proofs around that the list doesn't actually contain duplicates. The
standard library provides a NoDup predicate in the Lists module and
you can "add" it to a normal list type using Specif.sig. So you in
this case you would represent your snatlist type as {xs : list nat |
NoDup xs}. Carrying proofs around and constructing new ones from them
can be quite painful, but at least the type is easy to define this
way.
The other alternative I see would be again to use normal lists, and
call a "normalization" function that removes duplicate every time this
is needed. This would be needed for instance when checking if two
lists possibly containing duplicates represent the same set.
Cheers,
Catalin
PS: I'm a beginner to Coq myself and was faced with a similar problem
recently, so I would take my own advice with a big grain of salt :)
On Wed, Mar 24, 2010 at 4:45 PM, Ruddy Hahn
wrote:
To represent sets of positive, I prefer to use a PositiveMap unit
(I have my own version of it, in which PositiveMap.equal a b = true => a = b).
It is mainly Patricia trees.
If you prefer to use nat, a funny way is to put "true" in the slot corresponding to the number;
the biggest being omitted.
So {3; 5; 8} is represented by
[false (*0*);
false (*1*);
false;
true (*3*);
false;
true;
false;
false
or even, define a:
Inductive natset :=
| Last: natset
| Add: natset -> natset
| Skip: natset -> natset.
(or use BinPos.positive which is isomorphic)
This makes a bijection from list bool to non-empty set.
Managing empty sets can be done with an "option (list bool)".
That seems stupid and inefficient, but in fact it is computationnaly faster for coq:
The previous structure:
cons (S (S (S O))) (cons (S (S (S (S (S O)))))) (cons (S (S (S (S (S (S (S (S O)))))))) nil)
23 constructors used
mine:
Skip (Skip (Skip (Add (Skip (Add (Skip (Skip Last)))))))
9 constructors used
adding/removing an element is also computationnaly faster, as you don't use the "nat_eq" function.
In fact, it is "Patricia stack" instead of "Patricia tree" and like Patricia trees, you can compress path
by using differences: {3; 5; 8} can be represented by: [3; 2 (*+3=5*); 3 (*+5=8*)]
(and also like Patricia trees, you won't really gain in coq, as the constructors of the nodes we skip are just
replaced by the constructors of the positive expressing the differences)
So, to represent sets, lists with no duplicates are not ideal IMHO.
But if you need to keep the order in which you got them, that is another thing...
So to
Cédric AUGER
Univ Paris-Sud, Laboratoire LRI, UMR 8623, F-91405, Orsay
- [Coq-Club] Lists without repetition of occurrences, Ruddy Hahn
- Re: [Coq-Club] Lists without repetition of occurrences, Adam Chlipala
- Re: [Coq-Club] Lists without repetition of occurrences, Martijn Vermaat
Catalin Hritcu
- Re: [Coq-Club] Lists without repetition of occurrences, AUGER
