- To: Adam Chlipala <adam AT chlipala.net>
- Cc: Ruddy Hahn <ruddy.hahn AT gmail.com>, coq-club AT inria.fr
- Subject: Re: [Coq-Club] Lists without repetition of occurrences
- Date: Wed, 24 Mar 2010 17:28:12 -0400
On Mar24, Adam Chlipala wrote:
> Ruddy Hahn wrote:
> >Inductive snatlist : Set :=
> > | snil : snatlist
> > | scons : forall (n : nat) (l : snatlist), ~ (occur n l) -> snatlist
> >with occur (n : nat) (l : snatlist) : Prop :=
> > | ocHead : forall (n : nat) (l : snatlist) (p : ~ (occur n l)),
> >occur n (scons n l p)
> > | ocCons : forall (m : nat) (l : snatlist) (p: ~ (occur n l)),
> > (occur m l) -> occur m (scons n l p)
> Even switching this won't help you. When defining mutually inductive
> types, none of the types being defined may appear in the type of
> another. Here you have [snatlist] appearing in the type of [occur],
> despite the fact that these types are mutually inductive. You will need
> to use some less direct encoding to achieve what you're looking for.
By the way, in Agda, you can define mutally inductive types where one is
indexed by the other. So in addition to defining this type with
induction-recursion, you can define it with two datatypes. However,
there is still a positivity restriction, so you can do your example by
defining "DoesntOccur" instead of negating "Occur":
data Nat : Set where
Z : Nat
S : Nat -> Nat
data Void : Set where
data Id {A : Set} (x : A) : A -> Set where
Refl : Id x x
mutual
data SNatList : Set where
SNil : SNatList
SCons : (n : Nat) -> (l : SNatList)
-> (DoesntOccur n l)
-> SNatList
data DoesntOccur (n : Nat) : (l : SNatList) -> Set where
ONil : DoesntOccur n SNil
OCons : forall {n' l p}
-> (Id n n' -> Void)
-> DoesntOccur n l
-> DoesntOccur n (SCons n' l p)
I'm not sure how well worked-out the theory of these mutually-indexed
inductive types is, though.
-Dan
- [Coq-Club] Lists without repetition of occurrences, Ruddy Hahn
- Re: [Coq-Club] Lists without repetition of occurrences,
Adam Chlipala
- Re: [Coq-Club] Lists without repetition of occurrences, Dan Licata
- Re: [Coq-Club] Lists without repetition of occurrences, Martijn Vermaat
- Re: [Coq-Club] Lists without repetition of occurrences, Catalin Hritcu
Adam Chlipala
