- To: coq-club AT inria.fr
- Subject: [Coq-Club] Register Command in the Vernacular
- Date: Mon, 22 Mar 2010 18:03:06 +0000 (UTC)
Hi,
I have been reading the theory files to help me understand the
available theories for cyclic integers. Ideally, I would to find or make
a library that extracts directly into Ocaml int's or int32/64's.
Upon reading theories/Numbers/Cyclic/Int31/Int31.v, I came across
a command I have not seen and cannot find documentation for:
Register.
As an example, there first occurrence looks like this:
Register digits as int31 bits in "coq_int31" by True.
I found a reference in the source code (tactics/extratactics.ml4) that
seems to make clear that the parser should accept this command but
I'm unclear what the purpose of this and whether/how I can use it in
my code.
Can anyone shed some light on this? Should this be added to the
reference manual?
Regards,
Tim Reed.
- [Coq-Club] Register Command in the Vernacular, Tim Reed
