Re: [Coq-Club] Insertion sorting on lists ... in the Coq standard library or where else?
chronological Thread
- From: "Matthew Brecknell" <matthew AT brecknell.net>
- To: "Catalin Hritcu" <catalin.hritcu AT gmail.com>, coq-club AT inria.fr
- Subject: Re: [Coq-Club] Insertion sorting on lists ... in the Coq standard library or where else?
- Date: Wed, 31 Mar 2010 08:15:22 +1000
Hi Catalin,
Catalin Hritcu wrote:
> I have a very basic question: is there any implementation of insertion
> sorting on lists in the Coq standard library?
I don't know about the standard library, but the first chapter of the
Coq'Art book [1] shows a simple verification of a functional insertion
sort implementation for lists of integers. The Coq script is available
from the website. IIRC, the example's formalisation of sortedness
requires a decidable total order, which means there is no need to be
concerned with the stability of the sorting algorithm.
[1]http://www.labri.u-bordeaux.fr/perso/casteran/CoqArt/index.html
If you are interested in generalising to lists of arbitrary type with a
decidable total *pre*order, including verification of stability, you
might like to take a look at Xavier Leroy's development [2]. This is for
a merge-sort algorithm, which involves some non-trivial recursion
schemes, so the development is considerably more involved.
[2]http://moscova.inria.fr/~xleroy/coq/Mergesort.html
Regards,
Matthew
- [Coq-Club] Insertion sorting on lists ... in the Coq standard library or where else?, Catalin Hritcu
- Re: [Coq-Club] Insertion sorting on lists ... in the Coq standard library or where else?, Matthew Brecknell
