Re: Elimination of an inductive object of sort Prop (Re: [Coq-Club] more on vectors)
chronological Thread
- Cc: coq-club <coq-club AT inria.fr>
- Subject: Re: Elimination of an inductive object of sort Prop (Re: [Coq-Club] more on vectors)
- Date: Wed, 28 Apr 2010 10:52:17 -0400
Martijn Vermaat wrote:
In the definitions of functions on vectors such as take, drop, and nth,
we would use proofs of 'le' ord 'lt', e.g.:
Definition vtake (n m : nat) : n<= m -> vector m -> vector n.
But unfortunately, we cannot deconstruct the proof of n<= m since it
lives in Prop. Now, my guess is that there is no real solution to this
problem, but then again, I'm still quite new to Coq.
This is actually pretty easy to do. You just need to find a decidable alternative to the predicate you're using. The proof then only comes into the picture to derive contradictions.
Require Import Omega.
Definition vtake (n m : nat) : vector m -> n <= m -> vector n.
refine (fix vtake (n m : nat) : vector m -> n <= m -> vector n :=
match n return vector m -> n <= m -> vector n with
| O => fun _ _ => vnil
| S n' => match m return vector m -> S n' <= m -> vector (S n') with
| O => fun _ _ => False_rect _ _
| S m' => fun v _ => vcons (vhead v) (vtake n' m' (vtail v) _)
end
end); omega.
Defined.
- Elimination of an inductive object of sort Prop (Re: [Coq-Club] more on vectors), Martijn Vermaat
- Re: Elimination of an inductive object of sort Prop (Re: [Coq-Club] more on vectors), Adam Koprowski
- Re: Elimination of an inductive object of sort Prop (Re: [Coq-Club] more on vectors), Roman Beslik
- <Possible follow-ups>
- Re: Elimination of an inductive object of sort Prop (Re: [Coq-Club] more on vectors), Adam Chlipala
