coq-club - Re: Elimination of an inductive object of sort Prop (Re: [Coq-Club] more on vectors)
chronological Thread
  • To: Adam Chlipala <adam AT chlipala.net>
  • Cc: coq-club <coq-club AT inria.fr>
  • Subject: Re: Elimination of an inductive object of sort Prop (Re: [Coq-Club] more on vectors)
  • Date: Wed, 28 Apr 2010 17:03:29 +0200
> This is actually pretty easy to do.  You just need to find a decidable
> alternative to the predicate you're using.  The proof then only comes
> into the picture to derive contradictions.
> Require Import Omega.
> Definition vtake (n m : nat) : vector m -> n <= m -> vector n.
>    refine (fix vtake (n m : nat) : vector m -> n <= m -> vector n :=
>      match n return vector m -> n <= m -> vector n with
>        | O => fun _ _ => vnil
>        | S n' => match m return vector m -> S n' <= m -> vector (S n') with
>                    | O => fun _ _ => False_rect _ _
>                    | S m' => fun v _ => vcons (vhead v) (vtake n' m'
> (vtail v) _)
>                  end
>    end); omega.
> Defined.
Thanks (again), I was clearly looking at this function the wrong way.
Although it doesn't make me look very good, it is great that is is
actually such a simple function :)
cheers,
Martijn
