- To: ben <Benedikt.Ahrens AT unice.fr>
- Cc: Coq Club <coq-club AT inria.fr>
- Subject: Re: [Coq-Club] Non strictly positive occurrence in constructor
- Date: Tue, 8 Jun 2010 15:01:31 +0200
- Domainkey-signature: a=rsa-sha1; c=nofws; d=gmail.com; s=gamma; h=mime-version:sender:in-reply-to:references:date :x-google-sender-auth:message-id:subject:from:to:cc:content-type :content-transfer-encoding; b=AxlBwD9wj3gjA7/qiAuj3ygaqvkg+PBwVYBZJrugsFAQAfyteya4Timz1lM4BEi5BY /qTI1w7k2SYLDR5yPeunQ45MHxvtPkXZstsDBVV88NcgecQOUYNThiY5x51DfoFrHs4P vCW9QbXqrklgoY6aDDi6T0NQWek8TD6+BGe70=
Maybe you could replace the fixpoint with an inductive (I hope I
didn't swap indices...) ?
Inductive vect X: nat -> Type :=
| vnil: vect X O
| vcons: forall n, X -> vect X n -> vect X (S n).
Inductive type: nat -> Type :=
| constr : forall n k, vect (type n) k -> type (S n).
Hope this helps,
Damien
2010/6/8 ben
<Benedikt.Ahrens AT unice.fr>:
> Dear all,
> I run into a "non strictly positive occurrence" in a situation which is
> similar to the following simplified example:
> Fixpoint n_prod (X : Type) (n : nat) : Type :=
> match n with
> | O => unit
> | S n => prod X (n_prod X n)
> end.
> Inductive type : nat -> Type :=
> (n_prod (type n) k) -> type (S n).
> Is there an "equivalent definition" which would be accepted by Coq?
> Thanks
> Benedikt
- [Coq-Club] Non strictly positive occurrence in constructor, ben
- Re: [Coq-Club] Non strictly positive occurrence in constructor, Damien Pous
