coq-club - Re: [Coq-Club] Non strictly positive occurrence in constructor
chronological Thread
  • To: Damien.Pous AT ens-lyon.fr, Cedric.Auger AT lri.fr
  • Cc: Coq Club <coq-club AT inria.fr>
  • Subject: Re: [Coq-Club] Non strictly positive occurrence in constructor
  • Date: Tue, 08 Jun 2010 16:46:40 +0200
Thanks for your comments, Cedric and Damien.
It was indeed possible to use an inductive type instead of the fixpoint,
as you did in the example.
Greetings
Benedikt
Damien Pous wrote:
> Maybe you could replace the fixpoint with an inductive (I hope I
> didn't swap indices...) ?
> Inductive vect X: nat -> Type :=
> | vnil: vect X O
> | vcons: forall n, X -> vect X n -> vect X (S n).
> Inductive type: nat -> Type :=
>  | constr : forall n k, vect (type n) k -> type (S n).
> Hope this helps,
> Damien
> 2010/6/8 ben
> <Benedikt.Ahrens AT unice.fr>:
>> Dear all,
>> I run into a "non strictly positive occurrence" in a situation which is
>> similar to the following simplified example:
>> Fixpoint n_prod (X : Type) (n : nat) : Type :=
>>  match n with
>>  | O => unit
>>  | S n => prod X (n_prod X n)
>>  end.
>> Inductive type : nat -> Type :=
>>        (n_prod (type n) k) -> type (S n).
>> Is there an "equivalent definition" which would be accepted by Coq?
>> Thanks
>> Benedikt
