- To: Laurent Th�ry <Laurent.Thery AT sophia.inria.fr>
- Cc: coq-club AT inria.fr
- Subject: Re: [Coq-Club] Reset and CoqIde
- Date: Thu, 10 Jun 2010 17:05:10 +0800
- Organization: INRIA
Hi Laurent,
Using Navigation does not allow to remove the induction principle
defined by Coq. A solution is to use CoInductive à la SSreflect or PG :)
Regards
On Thu, 2010-06-10 at 10:32 +0200, Laurent Théry wrote:
> sidi wrote:
> > Hi,
> > When Replaying some coq scripts in CoqIDE, I got an error message after
> > the execution a Reset in a context similar to the flowing :
> > Inductive toto : Type :=
> > | A : toto
> > | B : toto -> toto.
> > Reset toto_rect.
> > Error: Use CoqIDE navigation instead
> > If this is not a CoqIDE bug, I don't see why the user should get an
> > error msg.
> CoqIde doesn't accept Reset commands. To do reset you should use navigation
> instead (put you cursor to the definition you want to undo and click on
> go to cursor).
> Laurent
- [Coq-Club] Reset and CoqIde, sidi
- Re: [Coq-Club] Reset and CoqIde,
Laurent Théry
- Re: [Coq-Club] Reset and CoqIde, sidi
- Re: [Coq-Club] Reset and CoqIde, Pierre Boutillier
Laurent Théry
