coq-club - Re: [Coq-Club] Reset and CoqIde
chronological Thread
  • From: Pierre Boutillier <pierre.boutillier AT ens-lyon.fr>
  • To: sidi <Sidi.Ould_Biha AT inria.fr>
  • Cc: Laurent Th�ry <Laurent.Thery AT sophia.inria.fr>, coq-club AT inria.fr
  • Subject: Re: [Coq-Club] Reset and CoqIde
  • Date: Thu, 10 Jun 2010 11:26:58 +0200
Le 10 juin 10 à 11:05, sidi a écrit :
Hi Laurent,
Using Navigation does not allow to remove the induction principle
defined by Coq. A solution is to use CoInductive à la SSreflect or PG :)
Regards
Hi,
If you don't want Coq automatic induction principles at all, You can use the "(Un)set Elimination Schemes." command such as it is done in theories/Logic/JMeq.v.
All the best,
Pierre
