- From: St�phane Lescuyer <stephane.lescuyer AT inria.fr>
- To: Adam Koprowski <adam.koprowski AT gmail.com>
- Cc: Matthieu Sozeau <mattam AT mattam.org>, Thomas Braibant <thomas.braibant AT gmail.com>, coq-club <coq-club AT inria.fr>
- Subject: Re: [Coq-Club] Dreadful performance of setoid rewrite in Coq 8.3-beta & trunk.
- Date: Fri, 11 Jun 2010 11:14:23 +0200
On Fri, Jun 11, 2010 at 11:00 AM, Adam Koprowski
wrote:
> Btw. is there any reasonable way to "debug" resolution to figure out
> what's going on, in cases such as this one?
You can change the parameters of the resolution using Typeclasses
eauto := ... (cf 18.5.5 in Ref. Manual), for instance changing the
depth to something small enough that the resolution fails in
reasonable time, and looking at the output to see what instances the
system is trying to find. If on the other hand you are certain that
the adequate instances are available in the context, you can also try
switching from depth-first search to breadth-first search using the
bfs flag.
Hope this helps,
S.
I'm the kind of guy that until it happens, I won't worry about it. -
R.H. RoY05, MVP06
- [Coq-Club] Dreadful performance of setoid rewrite in Coq 8.3-beta & trunk., Adam Koprowski
- Re: [Coq-Club] Dreadful performance of setoid rewrite in Coq 8.3-beta & trunk., AUGER Cedric
Thomas Braibant
- Re: [Coq-Club] Dreadful performance of setoid rewrite in Coq 8.3-beta & trunk., Adam Koprowski
Matthieu Sozeau
Adam Koprowski
- Re: [Coq-Club] Dreadful performance of setoid rewrite in Coq 8.3-beta & trunk., Stéphane Lescuyer
Adam Koprowski
