- To: coq-club <coq-club AT inria.fr>
- Subject: [Coq-Club] Dreadful performance of setoid rewrite in Coq 8.3-beta & trunk.
- Date: Thu, 10 Jun 2010 12:06:17 +0200
- Domainkey-signature: a=rsa-sha1; c=nofws; d=gmail.com; s=gamma; h=mime-version:from:date:message-id:subject:to:content-type; b=ePFjN/JoiDwJSMqDprhsqFbaPgXWpc5sgPlkxy+osHnpHusQe6RUDqSt2n/V3odLk/ HMMenTHmX4lsa36rR+GvEoReuAAw/XyPhTPfdz6/CSnyfMKF8j36gs0+UmIBCXoiVNl9 KsZWybP8VlJMutOq4F+PBwFJ/yjbz0lLvHRF0=
Dear all,
I have a pretty simple example, attached below, where a rewrite step takes virtually no time in Coq 8.2pl1, but is very slow in newer versions. The timing is as follows:
Coq 8.2pl1: 0.2sec.
Coq 8.3-beta: 403.1sec.
Coq-trunk-13107: 158.1sec.
Any ideas where this huge difference comes from? This is not a made-up problem, as I have precise instances of this is my development and this problem effectively stops me from being able to upgrade to new versions. Any ideas?
Best,
Adam
--------------------------------- Coq script follows ---------------------------------
Require Import OrderedType OrderedTypeEx FSetAVL Setoid FSetProperties.
Inductive test := A | B | C.
Module Tord_mini <: MiniOrderedType.
Definition t := test.
Definition eq := @eq t.
Axiom eq_refl : forall x : t, eq x x.
Axiom eq_sym : forall x y : t, eq x y -> eq y x.
Axiom eq_trans : forall x y z : t, eq x y -> eq y z -> eq x z.
Axiom lt : t -> t -> Prop.
Axiom lt_trans : forall x y z : t, lt x y -> lt y z -> lt x z.
Axiom lt_not_eq : forall x y : t, lt x y -> ~ eq x y.
Parameter compare : forall x y : t, Compare lt eq x y.
End Tord_mini.
Module Tord := MOT_to_OT Tord_mini.
Module TTord := PairOrderedType Tord Tord.
Module P := FSetAVL.Make TTord.
Module PP := FSetProperties.Properties P.
Lemma test_rewrite x y :
P.eq x y ->
(P.mem (A, B) x, P.mem (B, C) x, P.mem (A, C) x) =
(P.mem (A, B) y, P.mem (B, C) y, P.mem (A, C) y).
Proof.
intros. Time rewrite H. reflexivity. (* This rewrite step is the problematic one... *)
Qed.
Adam Koprowski [http://adam-koprowski.net]
R&D @ MLstate [http://mlstate.com, 15 rue Berlier, 75013 Paris, France]
- [Coq-Club] Dreadful performance of setoid rewrite in Coq 8.3-beta & trunk., Adam Koprowski
- Re: [Coq-Club] Dreadful performance of setoid rewrite in Coq 8.3-beta & trunk., AUGER Cedric
- Re: [Coq-Club] Dreadful performance of setoid rewrite in Coq 8.3-beta & trunk., Thomas Braibant
