coq-club - Re: [Coq-Club] Writing tactics with dependent destruction
chronological Thread
  • To: Coq Club <coq-club AT inria.fr>
  • Subject: Re: [Coq-Club] Writing tactics with dependent destruction
  • Date: Sat, 19 Jun 2010 12:56:20 -0400
  • Domainkey-signature: a=rsa-sha1; c=nofws; d=gmail.com; s=gamma; h=sender:content-type:mime-version:subject:from:in-reply-to:date :content-transfer-encoding:message-id:references:to:x-mailer; b=Rc9yp9gfMmmM4YwaOv/rVWQJjzNSgE+gzKerwfeAKdC/HVZDwmY0C7bryGai9CH3ne Xo6ioUh7qh4x960BoZn5ramjq37cMOxVIRIb6k8wlvy+/xgU7AMUnjtQi9qMfnpli6QY d+rZ/501qwnm0EvkTZ2f6G6PqaSAyXk+fu0Hs=
Le 19 juin 2010 à 12:02, Gyesik Lee a écrit :
> Hi,
Hi,
> I would like to write some tactics using dependent destruction.
> (I'm using Coq8.2pl1)
> 1) Writing a tactic using dependent destruction is not possible?
> Let me first introduce an example:
> Parameter A B : Type.
> Inductive P : A -> B -> Prop :=
>  | All : forall a b, P a b.
> Ltac toto :=
>  match goal with
>    | H : P _ _ |- _ => dependent destruction H
>  end.
> Ltac toto1 := intros; toto.
> Lemma titi : forall a b c d,
>  P a b -> P c d.
> Proof.
> intros. toto.
> Applying the tactic "toto" triggers the following error message:
> Error: No matching clauses for match goal
>       (use "Set Ltac Debug" for more info).
> However, if you replace "dependent destruction H" with "assert False",
> for example,
> in the definition of toto, then it behaves as expected.
> I am wondering why.
There seems to be a bug in the interpretation of tactics. "dependent
destuction" is
defined as a tactic notation expecting an ident(H), while H is an hypothesis
(bound) name here.
If you redefine the notation like this it works:
Tactic Notation "dependent" "destruction" hyp(H) :=
  do_depelim' ltac:(fun hyp => do_case hyp) H.
In any case, you can use the underlying tactical directly which has no such
problems.
> 2) Is there a way to use "dependent destruction" with "as" like
> "inversion H as ..." or "destruct H as ... "?
By customizing the tactical I suppose yes. Have a look at the end of
Program.Equality for ideas (e.g. the [using] variants).
> 3) (not relevant to dependent destruction)
> Suppose, during a proof, you have assumptions as follows
> H : forall (x : A), Q x -> P x x
> a : A
> H0 : Q a
> How would you write a tactic which generates a new assumption (H1 : P a a)?
assert(H1:=H _ H0)? Or you mean how to match on the goal?
Hope this helps,
-- Matthieu
