- To: Matthieu Sozeau <mattam AT mattam.org>
- Cc: Coq Club <coq-club AT inria.fr>
- Subject: Re: [Coq-Club] Writing tactics with dependent destruction
- Date: Sun, 20 Jun 2010 02:29:36 +0900
- Domainkey-signature: a=rsa-sha1; c=nofws; d=gmail.com; s=gamma; h=mime-version:sender:in-reply-to:references:date :x-google-sender-auth:message-id:subject:from:to:cc:content-type :content-transfer-encoding; b=Nqg+MgBLoyuLUxFQUZMQxmXsb8CaW9YWyW6CeuZrn/EKdnrhGJJQcB7EbW7qXKr7p1 70tVzUzfFtZBfb86y7llg2yl2zsjqxR3ZWfiFluqMVcrAzmWGeOqqAluIHKXwm8o/Hp+ wGcxnGvsYacNTaBaBMHI/2yFNF5rOsienaxU8=
Hi Matthieu,
many thanks for the quick answer.
> If you redefine the notation like this it works:
> Tactic Notation "dependent" "destruction" hyp(H) :=
> do_depelim' ltac:(fun hyp => do_case hyp) H.
Is "do_depelim'" included in the Coq 8.3?
(In Coq 8.2pl1, it doesn't seem to be.)
> In any case, you can use the underlying tactical directly which has no such
> problems.
Sorry, understanding tacticals is still a hard work for me.
>> 2) Is there a way to use "dependent destruction" with "as" like
>> "inversion H as ..." or "destruct H as ... "?
> By customizing the tactical I suppose yes. Have a look at the end of
> Program.Equality for ideas (e.g. the [using] variants).
Thanks for hints.
>> 3) (not relevant to dependent destruction)
>> Suppose, during a proof, you have assumptions as follows
>> H : forall (x : A), Q x -> P x x
>> a : A
>> H0 : Q a
>> How would you write a tactic which generates a new assumption (H1 : P a a)?
> assert(H1:=H _ H0)? Or you mean how to match on the goal?
I meant "matching on the goal".
- [Coq-Club] Writing tactics with dependent destruction, Gyesik Lee
- Re: [Coq-Club] Writing tactics with dependent destruction,
Matthieu Sozeau
- Re: [Coq-Club] Writing tactics with dependent destruction, Gyesik Lee
Matthieu Sozeau
