- To: coq-club AT inria.fr
- Subject: Re: Re: [Coq-Club] Instantiations with apply - impossible to unify
- Date: Mon, 5 Jul 2010 17:53:11 +0200
Thank you, the references you gave me helped me to complete the proof.
However,
it still looks quite complicated:
Lemma test1 :
1 <= asr 10000 5.
Proof.
change (1 <= asr 10000 (1 + 4)).
rewrite asr_2 with (x:=10000) (y:=1) (z:=4).
rewrite asr_1 with (x:=10000).
change (1 <= asr 5000 (1 + 3)).
rewrite asr_2 with (x:=5000) (y:=1) (z:=3).
rewrite asr_1 with (x:=5000).
change (1 <= asr 2500 (1 + 2)).
rewrite asr_2 with (x:=2500) (y:=1) (z:=2).
rewrite asr_1 with (x:=2500).
change (1 <= asr 1250 (1 + 1)).
rewrite asr_2 with (x:=1250) (y:=1) (z:=1).
rewrite asr_1 with (x:=1250).
change (1 <= asr 625 1).
rewrite asr_1.
change (1 <= 312).
intuition.
intuition.
intuition.
intuition.
intuition.
intuition.
intuition.
intuition.
intuition.
intuition.
Save.
For each step of simplification, I have to manually calculate the values for
[change] and [rewrite], which works of course, but is a lot of work.
- Is there a way to let Coq automatically determine which values for x,y,z
will match?
- Can I solve all 10 subgoals I have in the end with a single call of
intuition
at once? I found out how to use [repeat], but it only seems to apply a tactic
multiple times to a single subgoal, not to multiple subgoals at once.
- [Coq-Club] Instantiations with apply - impossible to unify, Michael
- <Possible follow-ups>
- Re: Re: [Coq-Club] Instantiations with apply - impossible to unify, Michael
