coq-club - Re: Re: [Coq-Club] Instantiations with apply - impossible to unify
chronological Thread
  • To: Michael <michaelschausten AT googlemail.com>
  • Cc: coq-club AT inria.fr
  • Subject: Re: Re: [Coq-Club] Instantiations with apply - impossible to unify
  • Date: Mon, 5 Jul 2010 19:04:15 +0200
  • Domainkey-signature: a=rsa-sha1; c=nofws; d=gmail.com; s=gamma; h=mime-version:sender:in-reply-to:references:date :x-google-sender-auth:message-id:subject:from:to:cc:content-type; b=GbQmUJHWEmHMgztWG0A36e0oT2OZA+Ox4DdtymBm0i79iZc7vgJBIJ+XPbgEEo3R1L RjgOWPV99D7F4dQgqCQtNjeA5KP8Ga+QBVFMHeHeYkAKEb1emNd8df1LpW8A4zp0FHLq LuUf0X8yaM1HHkTOExzWtmd7vm9LNjpqZ9y88=
Hi Michael,
I think the best way to do that is to use Ltac (I don't know if you are familiar with it?).
For example, with
Ltac changep :=
match goal with
  |- 1 <= asr ?a ?b =>
    let c:= eval compute in a  in
    match (eval compute in (b-1)) with
      0 =>
         change (1 <= asr c (1+(b-1)));
         rewrite asr_1 ; intuition
   | ?d =>
         change (1 <= asr c (1+d)) ;
         rewrite asr_2 with (x:=c) (y:=1) (z:=d) ; intuition ;
         rewrite asr_1 with (x:=c) ; intuition
    end
end.
(which basically automatises what you did manually, and checks the case when b=1, in order to make sure it will stop)
all you have to do is invoke it "repeat changep"
and then you only have to prove 1 <= 625/2, which you can do manually or through another tactic.
Ltac is really useful for such things.
Hope this helps :-)
Cheers,
Marthe
On 5 July 2010 17:53, Michael <michaelschausten AT googlemail.com> wrote:
Thank you, the references you gave me helped me to complete the proof. However,
it still looks quite complicated:
Lemma test1 :
 1 <= asr 10000 5.
Proof.
change (1 <= asr 10000 (1 + 4)).
rewrite asr_2 with (x:=10000) (y:=1) (z:=4).
rewrite asr_1 with (x:=10000).
change (1 <= asr 5000 (1 + 3)).
rewrite asr_2 with (x:=5000) (y:=1) (z:=3).
rewrite asr_1 with (x:=5000).
change (1 <= asr 2500 (1 + 2)).
rewrite asr_2 with (x:=2500) (y:=1) (z:=2).
rewrite asr_1 with (x:=2500).
change (1 <= asr 1250 (1 + 1)).
rewrite asr_2 with (x:=1250) (y:=1) (z:=1).
rewrite asr_1 with (x:=1250).
change (1 <= asr 625 1).
rewrite asr_1.
change (1 <= 312).
intuition.
intuition.
intuition.
intuition.
intuition.
intuition.
intuition.
intuition.
intuition.
intuition.
Save.
For each step of simplification, I have to manually calculate the values for
[change] and [rewrite], which works of course, but is a lot of work.
- Is there a way to let Coq automatically determine which values for x,y,z
will match?
- Can I solve all 10 subgoals I have in the end with a single call of intuition
at once? I found out how to use [repeat], but it only seems to apply a tactic
multiple times to a single subgoal, not to multiple subgoals at once.
