- To: coq-club AT inria.fr
- Subject: [Coq-Club] is matching bool slower than sum?
- Date: Sun, 18 Jul 2010 12:57:51 -0400
- Domainkey-signature: a=rsa-sha1; c=nofws; d=gmail.com; s=gamma; h=mime-version:sender:date:x-google-sender-auth:message-id:subject :from:to:content-type; b=vwipBgNdw+VMROJK/+9azdjlE4ifwWT1DyRwsxGGmofaqtteZHPrunJ9QMTl3hECaR 0ufowMAqlkhtnYhbOix5tCa/Ik4dnA7CoywuqlI2yeOFifZflyE7qupOY7UkBtRakbUK WywJzUZwZNWyzFQHHCfOyPa02NnXd3zIJkOAA=
Hi,
For some reason I have a definition 'insnEq' that compares two 'insn's
and returns bool. The 'insn' defines instructions in a language. What
'insnEq' does is just matching the two instructions and checking if
their sub-components are equal with corresponding 'comparison'
functions (which are defined in the similar fashion). Then I defined
others 'Fixpoint's :
Fixpoint InInsns (i:insn) (li:list insn) {struct li} : bool :=
match li with
| nil => false
| i' :: li' => insnEq i i' || InInsns i li'
end.
Definition block := list insn.
Fixpoint foo(i:insn) (lb:list block) {struct lb} : option block :=
match lb with
| nil => None
| b::lb' =>
match (InInsns i b) with
| true => Some b
| false => foo i lb'
end
end.
The compilation of foo is very slow, it takes around 2-3 mins. But, if
I proved this decidability lemma first,
Lemma InInsns_dec : forall i b,
{InInsns i b = true} + {InInsns i b = false}.
Proof.
intros. destruct (InInsns i b); auto.
Qed.
and then let foo match InInsns_dec,
Fixpoint foo2(i:insn) (lb:list block)) {struct lb} : option block :=
match lb with
| nil => None
| b::lb' =>
match (InInsns_dec i b) with
| left => Some b
| right => foo2 i lb'
end
end.
Coq compiles this foo2 immediately. Why is the first 'foo' slow?
Thanks.
Jianzhou
- [Coq-Club] is matching bool slower than sum?, Jianzhou Zhao
- Re: [Coq-Club] is matching bool slower than sum?, Thomas Braibant
Ryan Wisnesky
- Re: [Coq-Club] is matching bool slower than sum?, Jianzhou Zhao
- Re: [Coq-Club] is matching bool slower than sum?, Bruno Barras
