coq-club - Re: [Coq-Club] [change]: "not convertible"
chronological Thread
  • Cc: coq-club AT inria.fr
  • Subject: Re: [Coq-Club] [change]: "not convertible"
  • Date: Mon, 26 Jul 2010 15:36:34 +0200
Michael a écrit :
> Hello,
> I'm trying to proof an inequality like the following:
> Lemma lem1:
> forall (x:Z),
> (x * 64 / 8 + 1) >= x * 8.
> I tried to start changing the term:
> change ((x * 8 + 1) >= x * 8).
> but I receive the error message "Error: not convertible". It seems to have
> something to do with the brackets. If the statement is (x * (64 / 8) ...), I
> can easily change the term, and prove it.
> My first thought was, it might be because of x being of type Z, so in
> general,
> x * y / z <> x * (y / z), if x * y is not a multiple of z. I then tried
> another
> Lemma:
> Lemma lem2:
> forall (x:Z),
> x - 5 + 3 = x - 2.
> In this simple example, I could of couse prove it with intuition in a single
> step. But even here, "change (x - 2 = x - 2)" fails already.
> Why can't I change the terms in those 2 cases?
> In general, what is the best approach to simplify more complex inequalities
> of
> such type?
> Sincerely,
> Michael
Hello,
Actually, your two terms are not convertible, so you need auxilary
lemmas to prove the transformation.
I such case you can use the replace tactic :
 Require Import Omega.
Lemma lem1:
forall (x:Z),
(x * 64 / 8 + 1) >= x * 8 +1.
  intros x.
   replace (x * 64 / 8)with(x * 8) .
    (* this replace (x * 64 / 8) with (x * 8) in the goal an add a new
goal asking to prove x * 64 / 8= x * 8 *)
   omega. (* here I use omega to solve  (x * 64 / 8 + 1) >= (x * 64 / 8
+ 1) because Zge seems to not be proved reflexive)
    (* for proving x * 64 / 8= x * 8 you have to use Zdiv_mult_cancel_r
which need something in the form (x*z/y*z =x/y), I find it using Search
Pattern ( ?x*?y/?z = _ ) *)
   replace (64) with (8*8) by (simpl; reflexivity).
   replace (x*(8*8)) with (x*8*8) by (auto with zarith).
Qed.
Sincerly,
Julien.
