- To: Alexandre Pilkiewicz <alexandre.pilkiewicz AT polytechnique.org>
- Cc: Coq Club <coq-club AT inria.fr>
- Subject: Re: [Coq-Club] [LTac] Iteration on all hypothesis
- Date: Wed, 11 Aug 2010 14:25:13 -0400
Alexandre Pilkiewicz wrote:
I would like to iterate *once* on all the hypothesis of the current
goal. Something like
repeat
(match goal with
| H : _ |- _ => ....
end).
would not work because I don't want to clear H and the action I want
to associate won't fail if repeated, so it loops forever.
Are they any better solution?
You can build a list of candidate hypotheses by getting each hypothesis out of the way as you first select it. For instance, run [generalize dependent H] inside your loop, and then [intros] all the hypotheses back into place afterward, once you've built a list of hypotheses (say, as a tuple).
- [Coq-Club] [LTac] Iteration on all hypothesis, Alexandre Pilkiewicz
- Re: [Coq-Club] [LTac] Iteration on all hypothesis, Adam Chlipala
Adam Chlipala
- Re: [Coq-Club] [LTac] Iteration on all hypothesis, Carlos Simpson
Adam Chlipala
- Re: [Coq-Club] [LTac] Iteration on all hypothesis, Eric Jaeger
