- To: "Alexandre Pilkiewicz" <alexandre.pilkiewicz AT polytechnique.org>, "Coq Club" <coq-club AT inria.fr>
- Subject: Re: [Coq-Club] [LTac] Iteration on all hypothesis
- Date: Wed, 11 Aug 2010 20:52:04 +0200
- Organization: SGDN / DCSSI
I would like to iterate *once* on all the hypothesis of the current
goal. Something like
repeat
(match goal with
| H : _ |- _ => ....
end).
would not work because I don't want to clear H and the action I want
to associate won't fail if repeated, so it loops forever.
Are they any better solution?
I encountered the same difficulty, see the previous messages on this list titled "Ltac again" and more specifically my last (and unnecessary long) message on 26 May for various solutions and related problems. In a nutshell, the most generic solution - compatible with clearing, renaming, and so on - was this one (Coq code begin here, version 8.2 if I'm correct - completed as I've just discovered that my message was missing a piece of the code):
(* Basic definition ------------------------------------------------------------------------------*)
Definition typeof(T:Type)(t:T) := T.
Implicit Arguments typeof [T].
(* (typeof t) is similar to (type of t) but is an expression instead of a tactic. This for example
allow for using (unify (typeof t) T) instead of let T':=type of t in unify T' T. *)
(* Application to a given hypothesis -------------------------------------------------------------*)
Inductive _context_ :=
| _ctx_nil_ : _context_
| _ctx_cns_ : forall (T:Type), T->_context_->_context_.
(* A type to store coq proof contexts *)
Ltac _ctx_mem_ T t c :=
match c with
| _ctx_nil_ => false
| _ctx_cns_ ?T' ?t' ?c' => match T with
| T' => match t with t' => true | _ => _ctx_mem_ T t c' end
end
end.
(* Test whether or not (T,t) is a member of context c *)
Ltac _ctx_lgt_ c :=
match c with
| _ctx_nil_ => constr:(0)
| _ctx_cns_ _ _ ?c' => let l := _ctx_lgt_ c' in constr:(S l)
end.
(* Returns the length of context c *)
Ltac build_context_ acc :=
match goal with
| [ H:?T|-_ ] => match _ctx_mem_ T H acc with false => build_context_ (_ctx_cns_ T H acc) end
| _ => acc
end.
(* Returns a context (a list of type,value pairs) with all hypotheses; note that we browse hyps
using backtracking, and that to avoid to use the tactic fail (not compatible with this tactic
returning a value) backtracking is caused by incomplete pattern matching *)
Ltac get_nth_ n :=
let ctx := build_context_ _ctx_nil_ in
let rec gn_ n c :=
match c with _ctx_cns_ ?t' ?h' ?c' => match n with 1 => h' | S ?n' => gn_ n' c' end end
in gn_ n ctx.
(* Returns the identifier of the "n"th hypothesis in the context (first at top) *)
Tactic Notation "exec" tactic(T) "on" "hyp" constr(E) := let H := get_nth_ E in T H.
(* Mapping to all hypotheses ---------------------------------------------------------------------*)
Ltac map_hyps_ T :=
let c := build_context_ _ctx_nil_ in
let rec mh_ c := match c with _ctx_cns_ ?t' ?h' ?c' => mh_ c'; T h' | _ctx_nil_ => idtac end
in mh_ c.
(* Note that we prefer to build the context once and to use it, rather than invoking get_nth_ that
rebuilds the context each time *)
Tactic Notation "exec" tactic(T) "on" "hyps" := map_hyps_ ltac:(T).
(* In a context "H1 ... Hn", invoke "T Hn", ..., "T H1" *)
Tactic Notation "exec" tactic(T) "on" "hyps" "except" ident(I) :=
map_hyps_ ltac:(fun X=>match X with I => idtac | _ => T X end).
(* In a context "H1 ... Hx ... Hn", invoke "T Hn", ..., "T Hx+1", "T Hx-1", ..., "T H1" *)
Tactic Notation "exec" tactic(T) "on" "hyps" "in" constr(E) :=
map_hyps_ ltac:(fun X=>try (unify (typeof X) E; T X)).
(* In a context "H1 ... Hn", invoke "T Hn" if "Hn:E", ..., "T H1" if "H1:E" *)
(* Mapping to pairs of hypotheses ----------------------------------------------------------------*)
Ltac map_pairs_ T :=
let rec mp_ c1 c2 :=
match c1 with
| _ctx_cns_ ?t1' ?h1' ?c1' => match c2 with
| _ctx_cns_ ?t2' ?h2' ?c2' => mp_ c1 c2'; match h1' with
| h2' => idtac
| _ => T h1' h2'
end
| _ctx_nil_ => mp_ c1' c1'
end
| _ctx_nil_ => idtac
end
in mp_ c c.
Tactic Notation "exec" tactic(T) "on" "pairs" := map_pairs_ ltac:(T).
(* In a context "H1 ... Hn", invoke "T Hn-1 Hn", "T Hn-2 Hn", "T Hn-2 Hn-1", ..., "T H1 H2",
"T H1 H1" (that is invocation over all pairs "Hi" and "Hj" with i<j) *)
Tactic Notation "exec" tactic(T) "on" "pairs" "in" constr(E) :=
map_pairs_ ltac:(fun X Y=>try (first [ unify (typeof X) E | unify (typeof Y) E ]; T X Y)).
(* As for "exec on pairs", except that at least one of the components has to be in "E" *)
Tactic Notation "exec" tactic(T) "on" "pairs" "in" constr(E1) "and" constr(E2) :=
map_pairs_ ltac:(fun X Y=>try (first [ unify (typeof X) E1; unify (typeof Y) E2
| unify (typeof X) E2; unify (typeof Y) E1]; T X Y)).
(* As for "exec on pairs", except that one component has to be in "E1" and the other in "E2" *)
(* Mapping to couples of hypotheses --------------------------------------------------------------*)
Ltac map_couples_ T :=
let rec mc_ c1 c2 :=
match c1 with
| _ctx_cns_ ?t2' ?h2' ?c2' => mc_ c1 c2'; T h1' h2'
| _ctx_nil_ => mc_ c1' c
end
| _ctx_nil_ => idtac
end
in mc_ c c.
Tactic Notation "exec" tactic(T) "on" "couples" := map_couples_ ltac:(T).
(* In a context "H1 ... Hn", invoke "T Hn Hn", "T Hn Hn-1", ..., "T Hn H1", "T Hn-1 Hn", ...,
"T H1 Hn", ... "T H1 H1" *)
Tactic Notation "exec" tactic(T) "on" "true" "couples" :=
map_couples_ ltac:(fun X Y=>match X with Y => idtac | _ => T X Y end).
(* In a context "H1 ... Hn", invoke "T Hn Hn-1", ..., "T Hn H1", "T Hn-1 Hn", "T Hn-1 Hn-2", ...,
"T H1 Hn", ... "T H1 H2" (all couples except the reflexive ones) *)
Tactic Notation "exec" tactic(T) "on" "couples" "in" constr(E1) "*" constr(E2) :=
map_couples_ ltac:(fun X Y=>try (unify (typeof X) E1; unify (typeof Y) E2; T X Y)).
(* As for "exec on couples" except the pair has to be in E1*E2 *)
Tactic Notation "exec" tactic(T) "on" "true" "couples" "in" constr(E1) "*" constr(E2) :=
| Y => idtac
| _ => try (unify (typeof X) E1; unify (typeof Y) E2; T X Y)
end).
(* As for "exec on true couples" except the pair has to be in E1*E2 *)
Tactic Notation "exec" tactic(T) "on" "couples" "in" constr(E) "*" "_" :=
map_couples_ ltac:(fun X Y=>try (unify (typeof X) E; T X Y)).
Tactic Notation "exec" tactic(T) "on" "true" "couples" "in" constr(E) "*" "_" :=
| Y => idtac
| _ => try (unify (typeof X) E; T X Y)
end).
Tactic Notation "exec" tactic(T) "on" "couples" "in" "_" "*" constr(E) :=
map_couples_ ltac:(fun X Y=>try (unify (typeof Y) E; T X Y)).
Tactic Notation "exec" tactic(T) "on" "true" "couples" "in" "_" "*" constr(E) :=
| Y => idtac
| _ => try (unify (typeof Y) E; T X Y)
end).
(* Additional tools ------------------------------------------------------------------------------*)
Tactic Notation "remove" "duplicates" :=
exec (fun X Y=>try (unify (typeof X) (typeof Y); first [clear Y | clear X])) on pairs.
(* In a context with "Hi:T Hj:T", try to clear "Hj", then if unsuccessful "Hi" *)
Ltac rem_occ_ n T :=
match n with
| 0 => exec (fun X=>try (clear X)) on hyps in (typeof T)
| S ?n' => exec (fun X=>try (rem_occ_ n' (T X))) on hyps
end.
Tactic Notation "remove" "instances" constr(n) "of" constr(E) := try (rem_occ_ n E).
(* Remove n-instances of E, that is hypotheses of the form "E x1 x2 ... xn" *)
Tactic Notation "remove" "all" "instances" "of" constr(E) :=
try (rem_occ_ 5 E); try (rem_occ_ 4 E); try (rem_occ_ 3 E); try (rem_occ_ 2 E);
try (rem_occ_ 1 E); try (rem_occ_ 0 E).
(* Remove all instances of E, that is hypotheses of the form "E", "E x", "E x1 x2", etc. *)
Tactic Notation "new" constr(E) "as" ident(I) :=
match goal with [ _:?T|-_ ] => unify T (typeof E) | _ => generalize E; intro I end.
(* Creates an hypothesis "I:E" provided no other hypothesis of type "E" exists *)
Ltac symm_sat_ H := exec (fun X=>try (let H' := fresh X in new (@H _ _ X) as H')) on hyps.
Tactic Notation "close" "by" "symmetry" constr(E) := symm_sat_ E.
(* Generate new results from hypotheses and symmetry "H:forall x y, R x y->R y x" *)
Ltac trans_sat_ H :=
repeat (exec (fun X Y=>try (let H' := fresh X Y in new (@H _ _ _ X Y) as H')) on couples).
Tactic Notation "close" "by" "transitivity" constr(E) := trans_sat_ E.
(* Generate new results from hypotheses and transitive "H:forall x y z, R x y->R y z->R x z" *)
Ltac asym_sat_ H :=
repeat (exec (fun X Y=>try (let H' := fresh X Y in new (@H _ _ X Y) as H')) on couples).
Tactic Notation "close" "by" "antisymmetry" constr(E) := asym_sat_ E.
(* Generate new results from hypotheses and antisymmetry "H:forall x y z, R x y->R y x->_" *)
- [Coq-Club] [LTac] Iteration on all hypothesis, Alexandre Pilkiewicz
- Re: [Coq-Club] [LTac] Iteration on all hypothesis,
Adam Chlipala
Adam Chlipala
- Re: [Coq-Club] [LTac] Iteration on all hypothesis, Carlos Simpson
Adam Chlipala
- Re: [Coq-Club] [LTac] Iteration on all hypothesis, Eric Jaeger
Adam Chlipala
