- To: coq-club AT inria.fr
- Subject: [Coq-Club] Reasoning about integer constraint systems
- Date: Thu, 26 Aug 2010 18:28:53 +0200
Hallo!
The question I have is probably due to my limited understanding of Coq and best practises when it comes to enconding certain mathematical objects. I'd like to encode constraint systems on integers that are conjunctions of inequalities (x_1 <> x_2) and equations of the form x_1 + ... + x_n = k and proof that such a system has a solution. Encoding the constraints as propositions is straight forward, but I do not know how to express the proposition that this system has a solution which on papar I'd write as something like: Exists x_1, ..., x_n : Z | c_1 /\ ... /\ c_k (where the c_i are the individual constraints). Can you suggest a way to do this or should I rethink the whole approach? Thank you.
Thomas
- [Coq-Club] Reasoning about integer constraint systems, Thomas Strathmann
- Re: [Coq-Club] Reasoning about integer constraint systems, Evgeny Makarov
