- To: coq-club AT inria.fr
- Subject: Re: [Coq-Club] Reasoning about integer constraint systems
- Date: Fri, 27 Aug 2010 20:36:50 +0400
- Domainkey-signature: a=rsa-sha1; c=nofws; d=gmail.com; s=gamma; h=mime-version:in-reply-to:references:date:message-id:subject:from:to :content-type; b=neSVjKms/fpwOz+K4YqZhYeZzaMK20iM/KoM0KZJG1VlBUyjiUxy2KPj3Dw3ipvo5B DoDtABAqP4r6a27+j0x+hxWvtebWaqlK0bC274QwXPJcodb3TTfG+foc+1K1WbWIQpfQ 0VByc5LrMUEXtmIEIX+kM3D3FuhI184xmicFg=
Hello,
If you just want to write a proposition that a particular constraint
system has a solution, then you can just write, e.g.,
Implicit Types x : Z.
Theorem t : exists x1, exists x2, exists x3, x1 <> x2 /\ x1 + x2 + x3 = 5.
Then you can prove the existence of a solution only for this
particular system. However, if you want to reason about arbitrary
systems and prove meta-results, like "every system with at most three
constraints has a solution", then you need to encode constraints as a
Coq datatype. Then you will be able to write functions that operate on
such systems, e.g., create them or take them apart. This is in
contrast to propositions like t : Prop above: you can pass t around as
a first-class value, but you can't match it against a pattern.
So, for example, you could have the following development.
Require Import List.
Require Import Omega.
Inductive constraint : Set :=
| cneq : nat -> nat -> constraint (* cneq i1 i2 means x_{i1} <> x_{i2}
| ceq : list nat -> nat -> constraint. (* ceq (i1 :: i2 :: ...) k
means x_{i1} + x_{i2} + ... = k *)
(* sum_idx (i_1 :: i_2 :: ...) (x_1 :: x_2 :: ...) = x_{i_1} + x_{i_2} + ...
Fixpoint sum_idx (is xs : list nat) : nat :=
match is with
| nil => 0
| i :: is' => nth i xs 0 + sum_idx is' xs
end.
(* Note: the following two function create propositions! *)
Definition con_eval (c : constraint) (xs : list nat) : Prop :=
match c with
| cneq i1 i2 => nth i1 xs 0 <> nth i2 xs 0
| ceq is k => sum_idx is xs = k
end.
Fixpoint con_list_eval (cs : list constraint) (xs : list nat) : Prop :=
match cs with
| nil => True
| c :: cs' => con_eval c xs /\ con_list_eval cs' xs
end.
Definition cs1 : constraint := cneq 0 1.
Definition cs2 : constraint := ceq (0 :: 1 :: 2 :: nil) 5.
Theorem t : exists xs : list nat, con_list_eval (cs1 :: cs2 :: nil) xs.
Proof.
exists (1 :: 2 :: 2 :: nil). simpl. repeat split; omega.
Defined.
Record true_con_system := mk_true_con_system {
cs : list constraint;
xs : list nat;
cs_true : con_list_eval cs xs
This is something called reflection; there is a chapter about it in
the Coq book. It is used to prove meta-results by encoding Coq
propositions as Coq datatypes.
Let us know if this does not answer your question.
Evgeny
- [Coq-Club] Reasoning about integer constraint systems, Thomas Strathmann
- Re: [Coq-Club] Reasoning about integer constraint systems, Evgeny Makarov
