- To: Adam Chlipala <adam AT chlipala.net>, Jeffrey Terrell <jeff AT kc.com>
- Cc: "coq-club AT inria.fr" <coq-club AT inria.fr>
- Subject: RE: [Coq-Club] Intros
- Date: Tue, 7 Sep 2010 08:37:23 +0000
- Accept-language: en-GB, en-US
Adam Chlipala wrote:
> (I'm not entirely sure if [intro] really does head normalization. It
> might use some other, similar reduction strategy.)
You are correct, intro does not quite do head normalization: if the goal is
not an explicit product or let-in, intro repeatedly tries to apply the "red"
reduction tactic, which tries to unfold the head constant and then reduces
all apparent head beta/iota/zeta redexes (reducing manifest applications of
fun/fix, match-withs and let-ins, when possible).
This is almost the same as doing head normalization, except if you goal
happens to be something like an explcit beta redex, in which case red does
nothing (try it!) and intro fails miserably. This does not happen too often
in fully interactive use because most high-level tactics have an epilogue
that beta-iota normalizes the goal, but does occur rather annoyingly this
when you start using more tacticals.
Georges
- [Coq-Club] Intros, Jeffrey Terrell
- Re: [Coq-Club] Intros,
Adam Chlipala
- RE: [Coq-Club] Intros, Georges Gonthier
Adam Chlipala
