- From: Christine Paulin <Christine.Paulin AT lri.fr>
- To: Z <zell08v AT orange.fr>
- Cc: coq-club <coq-club AT inria.fr>
- Subject: Re: [Coq-Club] How does the simpl. tactics behave?
- Date: Tue, 07 Sep 2010 08:28:16 +0200
The point of simpl is to decide when to do a delta-reduction (expanding a constant) in order to generate a reduction.
To introduce a beta-redex is not a sufficent condition for delta-expansion (otherwise any function will be expanded by simpl): simpl expands a name when it will introduce a beta-redex and then a iota-redex (match on a constructor or fixpoint on a constructor).
In case just a beta-redex is involved, unfold fx will do the job.
The reason to design simpl instead of unfold is that when the constant introduces a fixpoint reduction, the simpl reduction attempts to do a fold after reduction, such that the fixpoint reduction rule is expressed in term of the function name and not of the primitive Fix construction.
C. Paulin
On 09/07/2010 07:04 AM, Z wrote:
Thanks foe your answer.
According to the coq manual , sympl. did some kind of beta-iota
conversion. With the fx defined as
lambda x. (forall x, 0)
I think if simpl. really does the beta-conversion, it should be doing
like this:
( lambda x. (forall x, 0) ) 3
-->_beta (forall x, 0) [x<-3]
-->_beta 0
I do hope to know why simpl. does not give outr the result in this way?
Thanks for yorur ideas.
Zell.
On Mon, Sep 6, 2010 at 7:21 PM, Adam Chlipala
<adam AT chlipala.net
<mailto:adam AT chlipala.net>>
wrote:
Z wrote:
I find it strange this follwoing pretty simple proof does not
work. Apparently, simpl. does not do the work. Someone would
like to give me more ideas about this failure??
Definition fx (x:nat):nat := 0 .
Example test000: fx 3 = 0.
Proof. intros. simpl. Qed.
By contrary, this following proof goes well,
Inductive day:Type := |today : day |other: day.
Definition otherday (d: day): day := match d with |today =>
other |other=> today end.
Example test006: otherday today = other.
Proof. simpl. reflexivity. Qed.
[simpl] never solves goals; it just simplifies them. The proof
script from your second example proves your first example, too. In
both cases, [simpl] can be left out, since [reflexivity] works
modulo all legal simplifications that [simpl] might perform (and
others that [simpl] will never perform).
[simpl] only unfolds definitions when doing so causes some [match]
to simplify. I hope it's not hard to see the consequences of this
heuristic for the two examples, and why it leads to the [simpl]
behavior you see.
begin:vcard fn:Christine Paulin-Mohring n:Paulin-Mohring;Christine email;internet:christine.paulin AT lri.fr tel;work:+33 1 72 92 59 05 x-mozilla-html:FALSE version:2.1 end:vcard
- [Coq-Club] How does the simpl. tactics behave?, Z
- Re: [Coq-Club] How does the simpl. tactics behave?,
Adam Chlipala
Z
- Re: [Coq-Club] How does the simpl. tactics behave?, Christine Paulin
- Message not available
- Re: [Coq-Club] How does the simpl. tactics behave?, Adam Chlipala
Z
Adam Chlipala
