- To: Daniel Schepler <dschepler AT gmail.com>
- Cc: coq-club AT inria.fr
- Subject: Re: [Coq-Club] Proving eq_dep statements?
- Date: Wed, 08 Sep 2010 18:11:56 -0400
Daniel Schepler wrote:
Then I proved a lemma:
Lemma eq_dep_is_pair_equality_after_conversion:
forall (U:Type) (P:U->Type) (p q:U) (x:P p) (y:P q),
eq_dep U P p x q y<->
p = q /\
forall (e:P p=P q),
y = convert_equal_types (P p) (P q) e x.
That seems to abstract out the role of q in y's type enough so that I can now
"apply<- eq_dep_is_pair_equality_after_conversion" and then do rewrites.
But I was wondering if there was a more standard way to deal with dependent
types in proving statements like eq_dep.
I haven't used this library yet, but you might find it helpful:
http://www.pps.jussieu.fr/~gil/Heq/
The other problem I ran into is that when I tried to define the category of
categories, it gave a universe error. I think I see what it's complaining
about, that trying to input Category into an instance of Category violates the
type hierarchy. So I guess I'd need to say something like "the category of
level n categories is a level n+1 category". But I'm not sure how to do that.
Every few months, someone asks this question on coq-club. :)
The answer is that you are out of luck, if you want to keep encoding category theoretic concepts without introducing a layer of syntax. Coq has no universe polymorphism. Not only that, but there is no way to mention universe levels explicitly in source code, let alone quantify over unknown levels. (Maybe a Coq developer will point out some recent feature (perhaps debugging-oriented) for including explicit levels, but I've never seen one. :])
- [Coq-Club] Proving eq_dep statements?, Daniel Schepler
- Re: [Coq-Club] Proving eq_dep statements?, Adam Chlipala
- Re: [Coq-Club] Proving eq_dep statements?, Vladimir Voevodsky
ben
Daniel Schepler
ben
- Re: [Coq-Club] Proving eq_dep statements?, Daniel Schepler
- Re: [Coq-Club] Proving eq_dep statements?, David Leduc
ben
Daniel Schepler
