coq-club - Re: [Coq-Club] Proving eq_dep statements?
chronological Thread
  • To: Daniel Schepler <dschepler AT gmail.com>
  • Cc: coq-club AT inria.fr
  • Subject: Re: [Coq-Club] Proving eq_dep statements?
  • Date: Thu, 09 Sep 2010 10:56:47 +0200
hi,
[snipped]
Daniel Schepler wrote:
> Hi, I just recently started playing around with Coq.  So far I've input
> some
> basic definitions of category theory, and formalized van der Waerden's
> proof
> that the free group is a group structure on a set of reduced words.  But as
> part of that development, I ran into problems proving that functors are
> equal
> in general.
I ran into the same problems and i did the same thing as you in my
formalization. However, the issue is a theoretical one. Since your
equality on objects is convertability and hence on a meta-level, your
categories are not *strict*. The "correct" notion of functor is then
something called "anafunctor". In short, you should take a 2-categorical
point of view here, i. e.  you should opt for isomorphisms of functors,
not equality.
You might want to have a look at
http://ncatlab.org/nlab/show/strict+category
There was also a discussion about equality on objects on the
"Categories" mailing list at the beginning of this year.
> The other problem I ran into is that when I tried to define the category of
> categories, it gave a universe error.  I think I see what it's complaining
> about, that trying to input Category into an instance of Category violates
> the
> type hierarchy.
Sozeau uses type classes to define CAT, see somewhere on
http://mattam.org
Sorry for the imcomplete pointers. I can try to find the links if necessary.
Greetings
ben
