- From: Pierre Casteran <pierre.casteran AT labri.fr>
- To: Thomas Braibant <thomas.braibant AT gmail.com>
- Cc: filou AT labri.fr, coq-club AT inria.fr
- Subject: Re: [Coq-Club] boolean simplification
- Date: Thu, 07 Oct 2010 13:59:26 +0200
Hi Thomas,
In coq's doc, there is a mention "The tactic must be loaded by Require Import Ring. The ring structures must be declared with the Add Ring command (see below). The ring of booleans is predefined"
I couldn't find exactly this definition in the library. I assume that using ring and ring_simplify
on boolean expressions can be more efficient than autorewrite, and we should have
the possibility of solving equations that involve associativity and commutativity, but we may
lose properties of negb ?
Pierre
Le 07/10/2010 13:41, Thomas Braibant a écrit :
I often use :
Hint Rewrite
orb_false_r (** b || false -> b *)
orb_false_l (** false || b -> b *)
orb_true_r (** b || true -> true *)
orb_true_l (** true || b -> true *)
andb_false_r (** b&& false -> false *)
andb_false_l (** false&& b -> false *)
andb_true_r (** b&& true -> b *)
andb_true_l (** true&& b -> b *)
negb_orb (** negb (b || c) -> negb b&& negb c *)
negb_andb (** negb (b&& c) -> negb b || negb c *)
negb_involutive (** negb( (negb b) -> b *)
: bool_simpl.
Hint Rewrite<- andb_lazy_alt : bool_simpl. (** a&&& b -> a&& b *)
Hint Rewrite<- orb_lazy_alt : bool_simpl. (** a ||| b -> a || b *)
Ltac bool_simpl := autorewrite with bool_simpl in *.
which you can adapt to autorewriting in an hypothesis.
then, in your case, you can use "discriminate" to conclude.
With best regards,
thomas
On Thu, Oct 7, 2010 at 11:54
AM,<filou AT labri.fr>
wrote:
Hi all,
I was wondering if there exists a tactic to simplify boolean
expressions in hypotheses, such as in a goal of the form
H: a&& false&& b = true
False
I've tried "contradict H;ring" but it seems that ring doesn't deal with
inequalities.
Thanks,
Vincent
- [Coq-Club] boolean simplification, filou
- Re: [Coq-Club] boolean simplification,
Thomas Braibant
- Re: [Coq-Club] boolean simplification, Pierre Casteran
- Re: [Coq-Club] boolean simplification, Stéphane Glondu
- <Possible follow-ups>
- Re: [Coq-Club] boolean simplification, Laurent Théry
Thomas Braibant
