- To: filou AT labri.fr
- Cc: coq-club AT inria.fr, pierre.casteran AT labri.fr
- Subject: Re: [Coq-Club] boolean simplification
- Date: Mon, 11 Oct 2010 12:28:37 +0200
Le 07/10/2010 11:54,
filou AT labri.fr
a écrit :
I was wondering if there exists a tactic to simplify boolean
expressions in hypotheses, such as in a goal of the form
H: a && false && b = true
False
I've tried "contradict H;ring" but it seems that ring doesn't deal with
inequalities.
Indeed, ring deals only with equalities. In your case, you can do "ring_simplify in H" that will turn H into "false = true", which can then be solved by "discriminate".
Note that the boolean ring is declared in terms of andb and xorb. You should be able to express all boolean expressions in terms of these.
Cheers,
Stéphane
- [Coq-Club] boolean simplification, filou
- Re: [Coq-Club] boolean simplification,
Thomas Braibant
Pierre Casteran
- Re: [Coq-Club] boolean simplification, Pierre Casteran
Pierre Casteran
- Re: [Coq-Club] boolean simplification, Stéphane Glondu
- <Possible follow-ups>
- Re: [Coq-Club] boolean simplification, Laurent Théry
Thomas Braibant
