coq-club - Re: [Coq-Club] Fwd: type class issue in Coq 8.3
chronological Thread
  • To: St�phane Lescuyer <stephane.lescuyer AT inria.fr>
  • Cc: Coq Club <coq-club AT inria.fr>
  • Subject: Re: [Coq-Club] Fwd: type class issue in Coq 8.3
  • Date: Tue, 12 Oct 2010 17:34:24 -0400
  • Domainkey-signature: a=rsa-sha1; c=nofws; d=gmail.com; s=gamma; h=mime-version:sender:in-reply-to:references:date :x-google-sender-auth:message-id:subject:from:to:cc:content-type :content-transfer-encoding; b=MSNdnhGULbHGFHdTGRmp0luwG54X28O87iWqnk4Z1EyJy9mVlw2LqcVCZoLSS3Jfwv jTb3YJkrYEH/pLwW/xRqvvMHW5t4K6ugvAHIF3EGHpkkeVLmk/uFPwsxdR8bNwCZf4AL gY/eMfx6wWVwiWZObOqbHbPDtBewY92SwRwCU=
Ok.  I see a note now about "Generalizable Variables" as a new feature
in the CHANGES file.  I also found the new use of "Generalizable
Variables" in the SetoidDec.v file for Coq 8.3.  But it seems like a
bad idea for coqdoc to strip out that command if it is actually
relevant to interpreting the subsequent Coq definitions.
But all of this business about generalizable variables verges on a
little too much voodoo for my taste...I am personally happier to read
and write this definition --
Definition my_equiv_decb {A} {S: Setoid A} {_: EqDec S} (x y: A): bool :=
 if x == y then true else false.
-- which I understand to be precisely identical to the one I gave below.
Speaking of which...if anybody is willing to elaborate on when to use
"Superclasses" (ch. 18.4.1) as opposed to "Substructures" (ch.
18.4.2), I would be very interested to hear about that.  I could be
terribly mistaken, but they seem to accomplish pretty much the same
thing.
 - Aaron
2010/10/12 Stéphane Lescuyer
<stephane.lescuyer AT inria.fr>:
> Hi Aaron,
> This is the normal behaviour, and a difference between 8.2 and 8.3. In
> the special binder `{...}, it is convenient to have unbound variables
> be automatically generalized, this lets you write, say, "forall
> `{Bijection A B}" if you have the defined the class of bijections
> between two types, instead of having to explicitely write "forall {A
> B} `{Bijection A B}".
> In 8.2, such variables were automatically generalized (and marked as
> maximally implicit), but the issue is that if you wanted to use an
> existing object and you make a typo, Coq will proceed fine and
> generalize it. Therefore, starting with version 8.3, variables which
> can be generalized must be define with the command Generalizable
> Variables (see doc in 8.3 for exact syntax).
> Hope this helps,
> Stéphane
> On Tue, Oct 12, 2010 at 6:09 PM, Aaron Bohannon
> <bohannon AT cis.upenn.edu>
>  wrote:
>> Hi, I'm afraid I may have sent this to an out-dated Coq Club address.
>> Here it is again, just in case...
>> ---------- Forwarded message ----------
>> From: Aaron Bohannon
>> Date: Mon, Oct 11, 2010 at 2:40 PM
>> Subject: type class issue in Coq 8.3
>> To: Coq List
>> <coq-club AT pauillac.inria.fr>
>> Hi, consider the following situation.  We import SetoidDec; we check
>> that "equiv_decb" was defined in the file; and then we duplicate the
>> definition used in the SetoidDec file:
>> Require Import SetoidDec.
>> Print Implicit equiv_decb.
>> Definition my_equiv_decb `{EqDec A} (x y: A): bool :=
>> In Coq 8.2, this works fine.  In Coq 8.3rc1, I get an error when
>> executing the Definition:
>> Error: Unbound and ungeneralizable variable A
>> I only barely understand Coq's type classes as it is, so I am quite
>> confused and really have no idea whether it is a bug or a feature.
>> However, I could not find any account of this difference in the
>> COMPATIBILITY file, the CHANGES file, or the 8.3 manual.
>>  - Aaron
> I'm the kind of guy that until it happens, I won't worry about it. -
> R.H. RoY05, MVP06
