- To: Jean-Francois Monin <jean-francois.monin AT imag.fr>, AUGER Cédric <Cedric.Auger AT lri.fr>
- Cc: Coq Club <coq-club AT inria.fr>
- Subject: Re: [Coq-Club] (Not) About mutual recursion
- Date: Wed, 13 Oct 2010 14:00:01 +0900
- Domainkey-signature: a=rsa-sha1; c=nofws; d=gmail.com; s=gamma; h=mime-version:sender:in-reply-to:references:from:date :x-google-sender-auth:message-id:subject:to:cc:content-type :content-transfer-encoding; b=a6QkVZ1z2xrgar7EnyWakH2tezXVZwcolCsx0jTTtlGDF152IYSxNXz+Ufwi/qxiHh WwGjqpDRKratFGya8P37awaDw8fWafGSsaIzHkEymqKoZalpxDFH/X5uCTfMY3LyrOPd PIdUloMi1I/IjWfMvt0VmbDsmKw8AB1SA3FUo=
Hi,
I think yours ideas show a way how to linearize the propositional
disjunction so that the proof unicity holds. They will be useful in
many situations.
Thanks a lot.
Gyesik
2010/10/13 Jean-Francois Monin
<jean-francois.monin AT imag.fr>:
> Hello,
> There is a simple solution without bool.
> Fixpoint VarInk (t:toto) : Prop -> Prop :=
> fun A =>
> match t with
> | Var => True
> | Unit => A
> | Plus t0 t1 => (VarInk t0 (VarInk t1 A))
> end.
> What you want is (VarInk t False).
> Proving
> Lemma VarInk_unicity :
> forall (t : toto) (A: Prop), unicity A -> unicity (VarInk t A).
> is a piece of cake.
> Of course
> Definition unicity (P:Prop) := forall (p q: P), p=q.
> If you need the equivalence with your
> original definition, just prove (rather simple):
> Lemma varin_varink : forall t A, VarIn t \/ A -> VarInk t A.
> Lemma varink_varin : forall t A, VarInk t A -> VarIn t \/ A.
> Hope this helps,
> JF
> On Tue, Oct 12, 2010 at 02:40:28AM +0900, Gyesik Lee wrote:
>> Hi,
>> I am not sure if the title of the message is adequate, so I apologize
>> in advance for any possible confusion.
>> (* Consider the following inductive definition.*)
>> Inductive toto : Type :=
>> Var : toto
>> | Unit : toto
>> | Plus : toto -> toto -> toto.
>> (* Now I would like to check if a (t : toto) contains [Var] or not.
>> One possible definition is as follows *)
>> Fixpoint VarIn (t:toto) : Prop :=
>> match r with
>> | Var => True
>> | Unit => False
>> | Plus t0 t1 => (VarIn t0) \/ (VarIn t1)
>> end.
>> (* What I don't like with this definition is that I don't have the
>> proof unicity without using proof-irrelevance.
>> This doesn't mean that I don't like proof-irrelevance.
>> Lemma VarIn_unicity : forall (t : toto) (p q : VarIn t), p = q.
> Jean-Francois Monin
> CNRS-LIAMA, Project FORMES & Universite de Grenoble 1
> Office 3-605, FIT, Tsinghua University
> Haidian District, Beijing 100084, CHINA
> Tel: +86 10 62 79 69 79 ext 605
> Fax@LIAMA:
> +86 10 6264 7458
- Re: [Coq-Club] About mutual recursion, (continued)
Adam Chlipala
Gyesik Lee
Adam Chlipala
Gyesik Lee
- Re: [Coq-Club] About mutual recursion, Gyesik Lee
Adam Chlipala
- Re: [Coq-Club] About mutual recursion, AUGER Cedric
Gyesik Lee
Adam Chlipala
Gyesik Lee
- Re: [Coq-Club] About mutual recursion, Thorsten Altenkirch
- Re: [Coq-Club] (Not) About mutual recursion,
Jean-Francois Monin
- Re: [Coq-Club] (Not) About mutual recursion, Gyesik Lee
Adam Chlipala
