- To: coq-club <coq-club AT inria.fr>
- Subject: [Coq-Club] Trying to compile ssreflect (coqmktop error)
- Date: Wed, 13 Oct 2010 15:07:07 +0100
Hi,
I am trying to compile ssreflect. I have Coq installed through macports. At
first I tried to install ssreflect with 8.2pl1 but that didn't work, as ocaml
had since been upgraded to 3.12.0, which is not compatible with 8.2pl1.
Although version 8.2pl2 is not yet available in macports, I modified the
portfile to refer to 8.2pl2 (and disabled one patch which seems to have
already been included in 8.2pl2) to upgrade Coq -- that seemed to go fine.
Compilation of ssrcoq, following the instructions, then also worked fine
(that is, compilation didn't give any errors).
However, when I try to generate a version of coqide, things break:
[edsko@devriese2
~/csw/src/ssreflect-1.2/src]
# coqmktop -ide -opt ssreflect.cmx -o ../bin/ssrcoqide
File "/var/folders/kg/kgA4gpp3Gnu+Kv5tWCp9yE+++TI/-Tmp-/coqmaindd09f5.ml",
line 2, characters 17-29:
Error: Unbound module Coqide
I'm not sure what exactly the error means and how I could try to fix it.. Any
suggestions?
-E
- [Coq-Club] Trying to compile ssreflect (coqmktop error), Edsko de Vries
- <Possible follow-ups>
- Re: [Coq-Club] Trying to compile ssreflect (coqmktop error), Laurent Théry
