coq-club - Re: [Coq-Club] mechanizing the metatheory of coq
chronological Thread
  • To: coq-club AT inria.fr
  • Subject: Re: [Coq-Club] mechanizing the metatheory of coq
  • Date: Mon, 18 Oct 2010 18:50:25 +0200
On 10/15/2010 09:03 PM, Chris Casinghino wrote:
Hi all,
I'm curious about how much of the metatheory of Coq (or similar type
theories) has been formalized in Coq itself.  I'm particularly
interested in proofs of strong normalization/logical consistency.  I
know that Barras and Werner mechanized strong normalization of CC in
the "Coq in Coq" paper.  Has anyone done more?  In particular, has
anyone added data types, recursion, large eliminations, or a universe
hierarchy to these proofs?  Is there any speculation about how far one
could get before running up against Godel?
Hi Chris,
As you have guessed, my thesis only deals with the syntactic metatheory of CIC (without coinductive types), up to decidability of type-checking, assuming strong normalization.
Regarding strong normalization, I guess "Coq in Coq" is still the largest fragment of CIC formalized in Coq. Last year, I started formalizing set theoretical models of various type theories, starting from CC with universes. Since then, I have added natural numbers (with strong elimination) and have proved both consistency and strong normalization. In the consistency model, pattern-matching and fixpoint are separated, as in the implementation, but termination of recursive definitions is checked by tagging inductive types with size information (denoting ordinals). The normalization proof only supports the recursor, and it's a bit of work to model the reduction of the fixpoint operator alone. [see my paper in the Journal of Formalized Reasoning for the consistency model of CC+Nat]
I am almost done with (Brouwer) ordinals. I still need a lemma about cardinals, but I'd rather avoid relying on the axiom of choice (and the excluded-middle). Extending the results to the W type (which captures the full power of inductive types) should be straightforward.
Going back to your question about Godel, you could prove the consistency of CC with universes within ZF (Luo's thesis), so presumably in Coq without axiom. However, inductive types make universes much bigger, and Werner's "sets in types, types in sets" paper shows[*] that you probably need n inaccessible cardinals to model CIC with n universes. It's reasonable to conjecture that you can build a model of CIC with a finite number of universes within Coq, but this hasn't been established yet.
Bruno.
[*] in fact you need ZFC + inaccessible cardinals to model CIC + axiom of choice + a description axiom, but it's not clear whether you actually need the axiom of choice or the full power of inaccessible cardinals to build a model of CIC.
