coq-club - Re: [Coq-Club] [Type Classes]: avoid duplication of instances
chronological Thread
  • From: Alexandre Pilkiewicz <alexandre.pilkiewicz AT polytechnique.org>
  • To: St�phane Lescuyer <stephane.lescuyer AT polytechnique.org>
  • Cc: Aaron Bohannon <bohannon AT cis.upenn.edu>, Coq Club <coq-club AT inria.fr>
  • Subject: Re: [Coq-Club] [Type Classes]: avoid duplication of instances
  • Date: Mon, 18 Oct 2010 14:37:12 +0200
  • Domainkey-signature: a=rsa-sha1; c=nofws; d=gmail.com; s=gamma; h=mime-version:sender:in-reply-to:references:from:date :x-google-sender-auth:message-id:subject:to:cc:content-type :content-transfer-encoding; b=h7Yq/U4cJ+BDnnq/SNB8yz7Vhv2rFzMWgUaTWt7rETMR2jg2o0PpEjUtmyK3w/yPzu cl7sxvPlLF2fRvH8PydjehajL0D8uCzJD18wYDmTbeD14m7APflcB1nB3cDogTl8iptK oJNxPEEZOqcruGn3ENGgZsFQa1M2dHItJ4EFs=
Hi all
Le 12 octobre 2010 23:05, Stéphane Lescuyer
 a écrit :
> Indeed, the less I mix proofs and programs, the more happy I
> am :)
I generally agree with this statement, except in the case of...
decidability function!
When you use a decidability function instead of a boolean function, it
comes at almost no cost. Indeed, the "if" construct works, and with
the nice coercion
Definition proj_sumbool (P Q: Prop) (a: {P} + {Q}) : bool :=
  if a then true else false.
Implicit Arguments proj_sumbool [P Q].
Coercion proj_sumbool: sumbool >-> bool.
(from the coqlib.v file of compcert,
http://compcert.inria.fr/doc/html/Coqlib.html), you can even write
things like
if (peq p q) || (peq r s) then....
And when you need to program the function, two main situations occurs:
either you want to extract it/compute with it, or you don't.
In the last case, the "decide equality" tactic is pretty convenient
(it is actually convenient in the first case too). But if you really
want to make sure the code is the right one, the Program extension is
pretty efficient. Imagine you want a fast equality check on unit
Require Program.
Program Definition eq_dec_unit (u1 u2: unit):
  {u1 = u2} + {u1 <> u2}:=
  left _.
Next Obligation.
  destruct u1; destruct u2; reflexivity.
Qed.
and if you don't want to prove it directly in your code, you still
have the option Stéphane pointed earlier in the discussion, namely to
split your definition in a boolean function and a lemma.
My 2c.
