coq-club - Re: [Coq-Club] two related questions
chronological Thread
  • To: Vladimir Voevodsky <vladimir AT ias.edu>
  • Cc: Coq Club <coq-club AT inria.fr>
  • Subject: Re: [Coq-Club] two related questions
  • Date: Wed, 20 Oct 2010 09:58:21 +0100
Hi Vladimir,
> Hi, I have the following two questions:
> Q.1 Is it  impossible to prove in Coq that any two functions from empty
> type to empty type are equal ?
> Q.2 Is it possible to preserve extraction after adding the functional
> extensionality axiom ((forall x:X, f x = g x) -> f =g)?
People have already commented on this. Adding the axiom indeed preserves
extraction but it interferes with the  computational behaviour of Type
Theory: e.g. there are closed terms of type Nat which do not reduce to a
numeral. This means that equalities which should hold definitionally have to
be proven. However, this can be avoided, as we have shown in our paper
"Observational Equality, now"
(http://www.cs.nott.ac.uk/~txa/publ/obseqnow.pdf). This is going to be
implemented i Epigram 2 (I hope).
Also Martin Hofmann has shown that extensional type theory is conservative
over intensional type theory + ext + uip (uniqueness of identity proofs). It
would be nice to have a similar result without uip. However, then we have to
replace extensional type theory with something else ("univalent type theory"
or as I call it "higher dimensional type theory"). We certainly need
additional constants such as that the definable term
        extinv : forall f  g : A -> B,  (f = g) -> forall a : A -> (f a = g a)
is inverse to ext. But this won't be enough.
Cheers,
Thorsten
