- To: Adam Chlipala <adam AT chlipala.net>
- Cc: Coq Club <coq-club AT inria.fr>
- Subject: Re: [Coq-Club] running out of memory with big proof objects
- Date: Tue, 19 Oct 2010 18:34:04 -0400
- Domainkey-signature: a=rsa-sha1; c=nofws; d=gmail.com; s=gamma; h=mime-version:sender:in-reply-to:references:date :x-google-sender-auth:message-id:subject:from:to:cc:content-type :content-transfer-encoding; b=jtvfjRQaV4BWRukrXVA2mx4HH4WkX5VFFT6XusQpQ6K5bsWOE5WhHLVqpfTS3zC3VR Wc8goVn05qs2wXbcojALfPmytueDMpxIMFyrEhYyGE89S+xfphAL3tpY37+YumttRFzp Chmc05bJMiPYfz/7vK/7CVAbHP5Bv/OS8V2Cs=
On Tue, Oct 19, 2010 at 6:12 PM, Adam Chlipala
wrote:
> Aaron Bohannon wrote:
>> Hi, I am running into a performance issue. I have a moderately large
>> but straightforward proof. Basically, it breaks down into 256 cases,
>> almost all of which are solved by one use of the "inversion" tactic
>> (that does not generate additional subgoals), followed by a use of the
>> "congruence" tactic. It is easy to write a tactic definition to
>> finish the whole proof at once. It takes about 20 seconds on my
>> machine to run the tactic in CoqIDE, and get "Proof completed." If I
>> type "Qed," it takes about another 20 seconds to complete the proof.
>> If I say "Defined," CoqIDE will crash after about 20 seconds (coqc on
>> the command-line does not crash but doesn't work any faster).
> Have you tried wrapping each case-solving tactic with the [abstract]
> tactical? This can have a dramatic effect on the amount of memory used for
> intermediate data structures.
Thanks. With "abstract", I can use "Defined" without crashing CoqIDE,
and it works quickly (proof search is still slow, of course).
I'll look into the other tips, too, when I get a chance...
- Aaron
- [Coq-Club] running out of memory with big proof objects, Aaron Bohannon
- Re: [Coq-Club] running out of memory with big proof objects,
Adam Chlipala
- Re: [Coq-Club] running out of memory with big proof objects, Aaron Bohannon
Jim Apple
- Message not available
- Fwd: [Coq-Club] running out of memory with big proof objects,
Aaron Bohannon
Stéphane Lescuyer
Aaron Bohannon
- Re: [Coq-Club] running out of memory with big proof objects, Stéphane Lescuyer
Aaron Bohannon
Stéphane Lescuyer
Aaron Bohannon
Adam Chlipala
- [Coq-Club] Re: running out of memory with big proof objects, Adam Megacz
