- To: Coq Club <coq-club AT inria.fr>
- Subject: [Coq-Club] Equational Reasoning over streams
- Date: Thu, 21 Oct 2010 18:18:29 +0200
Dear all,
We are trying to prove a number of basic results over streams in Coq, typically staring from results that are standard in (infinitary) term rewriting, like defining zip, even and odd and showing that
zip (even s)(odd s) == s
Here, == is the coinductively defined equality over streams, EqSt in the standard library.
To make this all smooth and to be able to automate these proofs, we would like to use Setoid Rewriting.
Now, it is straightforward to declare == as an equivalence relation that is a congruence wrt functions like zip and even.
Then one can go and do rewriting in proofs, but the proofs can't be saved, becuase -- according to Coq's mechanism -- they are not guarded.
Has anyone encountered this situation before and found a solution?
One thing I have tried is to just assume that == is Leibniz equality on streams, so one can use the rewrite tactic itself.
Axiom ext : forall s t :Stream A, s == t -> s = t.
That doesn't help either, because the final proof of a statement involving == will not be guarded still.
For specific functions, like zip even and odd, there is always a way around the problem, by unfolding its definition and doing case analysis. However, we would like to find a generic method. (Possibly by assuming an axiom.)
Thanks
Herman Geuvers
- [Coq-Club] recursive Ltac definitions, Aaron Bohannon
- [Coq-Club] Re: recursive Ltac definitions,
Aaron Bohannon
- [Coq-Club] Equational Reasoning over streams, Herman Geuvers
- Re: [Coq-Club] Equational Reasoning over streams,
Thorsten Altenkirch
David Leduc
Herman Geuvers
- Re: [Coq-Club] Equational Reasoning over streams, AUGER Cedric
Keiko Nakata
- Re: [Coq-Club] Equational Reasoning over streams, David Leduc
Herman Geuvers
David Leduc
Thorsten Altenkirch
- Re: [Coq-Club] recursive Ltac definitions, Adam Chlipala
Aaron Bohannon
