- To: Herman Geuvers <herman AT cs.ru.nl>
- Cc: Coq Club <coq-club AT inria.fr>
- Subject: Re: [Coq-Club] Equational Reasoning over streams
- Date: Fri, 22 Oct 2010 19:06:46 +0200
Le Fri, 22 Oct 2010 14:11:38 +0200,
Herman Geuvers
a écrit :
I sent some patch suggestions to your developpement.
> Dear all,
> To clarify my mail, I append a small Coq file indicating what I am
> trying to prove.
> NB. I know that the Lemma even_zip can be proved in a different way,
> so the point of this file is not that I am stuck with even_zip.
> I am interested in using the setoid rewriting or the standard
> rewrite (using Leibniz eq) for streams. This is a kind of minimal
> file where this feature occurs and Coq doesn't accept my proof
> because of the guardedness constraint.
> (So maybe the answer is: You can't use (setoid) rewriting in Coq for
> this purpose.)
> Thanks
> Herman Geuvers
> Set Implicit Arguments.
> Require Import Streams.
> Require Export Setoid.
> Require Export Relation_Definitions.
> Infix "::" := Cons (at level 60, right associativity) :
> richstream_scope. Infix "==" := EqSt (at level 60) : richstream_scope.
> Ltac coinduction proof :=
> cofix proof; intros; constructor;
> [ clear proof | try (apply proof; clear proof) ].
> Open Scope richstream_scope.
> Section Zip.
> Variable A: Type.
> CoFixpoint zip(s: Stream A)(t: Stream A) : Stream A :=
> match s with
> | x :: xs => x :: (zip t xs)
> end.
> CoFixpoint even(s: Stream A) := hd s :: (even (tl(tl s))).
> End Zip.
Tactic Notation "cosimpl" ident(A) := (simpl; fold (@zip A); fold
(@even A)).
(* this is not a very convenient notation as you need to give the
* type; maybe some improvement can be done
> Section Congruence.
> Variable A:Type.
> Axiom ext : forall s t :Stream A, s == t -> s = t.
> Lemma leib : forall s t :Stream A, s = t -> s == t.
> Proof.
> intros s t Heq; rewrite Heq; apply EqSt_reflex.
> Qed.
> Lemma congruence : forall f : Stream A -> Stream A, forall s
> t :Stream A, s == t -> f s == f t.
> (* Impossible without ext *)
> Proof.
> intros f s t H. rewrite (ext H). apply EqSt_reflex.
> Qed.
> (* This works, because we don't do the proof by coinduction, but
> by the property of Leibiz equality *)
> Lemma even_zip_using_ext : forall (s t: Stream A), even (zip s t) ==
> s. Proof.
> intros s t.
> coinduction H; destruct s; destruct t.
> auto.
> (* Proof completed, but not guarded *)
> Abort.
(* I may be wrong, the cofixpoint is meant to be some producting
* process; in your proof script, the head is well produced;
* but the tail has no production guarantee, since it is obtained by
* rewritting.
* consider:
* Parameter A: Type.
* Parameter f: Stream A -> Stream A.
* CoFixpoint fid (s: Stream A) := hd s :: (f (fid (tl s))).
* Coq is not very happy with this definition.
* Maybe that an axiom of the form:
* "forall A (f: Stream A -> Stream A) B (g: B -> A),
* exists Recfg: Stream B -> Stream A,
* forall (s: Stream B), Recfg s = (g (hd s))::(f (Recfg (tl s)))"
* can save you…
Lemma even_zip_using_ext : forall (s t: Stream A), even (zip s t) == s.
Proof.
(* if you first introduce s and t, then using "coinduction" will block
* you since s and t will be fixed
* (generated hypothesis will be "even (zip s t) == s" for not yet
* destroyed s and t)
auto.
cosimpl A. (* this notation is to be improved *)
apply H.
Qed.
(* by the way do you know the "Guarded." instruction?
* If not, it can be very usefull; take a look in the manual.
* by the way2, is there a trick to make it available in
* in a tactic?
* Having a [Notation Tactic "guard" tactic(t) := (t; Guarded).]
* could be handy.
(* The rest of the file can be solved the same way without using
* rewriting; for these examples, rewritting is not very natural;
* maybe you can provide better examples?
- [Coq-Club] recursive Ltac definitions, Aaron Bohannon
- [Coq-Club] Re: recursive Ltac definitions,
Aaron Bohannon
- [Coq-Club] Equational Reasoning over streams,
Herman Geuvers
- Re: [Coq-Club] Equational Reasoning over streams,
Thorsten Altenkirch
David Leduc
Herman Geuvers
- Re: [Coq-Club] Equational Reasoning over streams, AUGER Cedric
Keiko Nakata
- Re: [Coq-Club] Equational Reasoning over streams, David Leduc
Herman Geuvers
David Leduc
Thorsten Altenkirch
Herman Geuvers
- Re: [Coq-Club] recursive Ltac definitions, Adam Chlipala
Aaron Bohannon
