[Coq-Club] implicitly generalizing binders: is this the expected behavior? (svn r13458)
chronological Thread
- To: coq-club AT inria.fr
- Subject: [Coq-Club] implicitly generalizing binders: is this the expected behavior? (svn r13458)
- Date: Fri, 22 Oct 2010 03:01:01 +0000
- Cancel-lock: sha1:bHYWTWbVryIqesuRG6eLtac0/Eo=
- Organization: Myself
* In the script below, Coq's responses are shown in comments with a ">".
* Commands which produce an error are commented out. This was attempted
* with SVN trunk r13458
Generalizable All Variables.
Section test.
Class class1 {m:nat} := { blah : nat }.
Context `(t:class1).
Class class2 `(t:class1) := { blah2 : nat }.
Print class2.
*> Record class2 (m : nat) (t : class1 m) : Type := Build_class2 { blah2
: nat }
*> For class2: Argument m is implicit and maximally inserted
*> For class2: Argument scopes are [nat_scope _]
*> For Build_class2: Argument scopes are [nat_scope _ nat_scope]
(* even though [m] is reported as implicit, Coq still will not accept this:
(*Context `(t2:class2 t).*)
(*> The term "t" has type "class1" while it is expected to have type
*> "nat". *)
(* yet this doesn't work either *)
(*Context `(t2:class2 _ t).*)
(*> Error: Typeclass does not expect more arguments *)
(* moreover, the following attempt also will not work; Coq
* synthesizes a new free variable [m0] and tries to unify it with
* the [m] synthesized when declaring [t], which, of course, fails.
* Is this the expected behavior? It would be better if Coq only
* generalized variables which it has no plans to try unifying later
* on, although perhaps that isn't easy to implement. *)
Set Printing Implicit.
(*Context `(t2:class2(t:=t)).*)
(*> The term "t" has type "@class1 m" while it is expected to have type
*> "@class1 m0". *)
(* this works *)
Context `(t2:@class2 _ t).
End test.
- [Coq-Club] implicitly generalizing binders: is this the expected behavior? (svn r13458), Adam Megacz
