- To: coq-club AT inria.fr
- Subject: [Coq-Club] Re: running out of memory with big proof objects
- Date: Thu, 21 Oct 2010 21:40:06 +0000
- Cancel-lock: sha1:hA87QBZlmsDdvyz9VA5TShcp5bA=
- Organization: Myself
Aaron Bohannon
<bohannon AT cis.upenn.edu>
writes:
> It seems like something must be wrong here. Is there something I
> should be using instead of "inversion H; congruence"?
If "destruct H" gives you the hypotheses you need (it doesn't always),
you might try using it instead of inversion. At least for me it speeds
things up dramatically.
- a
- [Coq-Club] running out of memory with big proof objects, Aaron Bohannon
- Re: [Coq-Club] running out of memory with big proof objects,
Adam Chlipala
- Re: [Coq-Club] running out of memory with big proof objects, Aaron Bohannon
Jim Apple
- Message not available
- Fwd: [Coq-Club] running out of memory with big proof objects,
Aaron Bohannon
Stéphane Lescuyer
Aaron Bohannon
- Re: [Coq-Club] running out of memory with big proof objects, Stéphane Lescuyer
Aaron Bohannon
Stéphane Lescuyer
Aaron Bohannon
Adam Chlipala
- [Coq-Club] Re: running out of memory with big proof objects, Adam Megacz
