- To: Vladimir Voevodsky <vladimir AT ias.edu>, Coq Club <coq-club AT inria.fr>
- Subject: RE: [Coq-Club] strange behavior of "Eval compute"
- Date: Thu, 28 Oct 2010 19:46:13 +0000
- Accept-language: en-GB, en-US
Evaluation is guaranteed to terminate, but not necessarily in your
lifetime...
If the definition you rendered opaque is a test performed by your recursive
function before the recursive calls, for instance, I would expect the
behaviour you describe: because it is unable to evaluate the test, Eval
unfolds the complete branching tree, which is exponential in the size of the
recursion depth -- and in practice, exponential is pretty much the same thing
as infinite.
-- Georges
-----Original Message-----
[mailto:vladimir AT ias.edu]
Sent: 28 October 2010 19:26
To: Coq Club
Subject: [Coq-Club] strange behavior of "Eval compute"
Hello,
I am using "Eval compute in ..." to compute a term of type nat which is
defined in a complicated way but should reduce to (S O). When all the
intermediate definitions are made transparent the computation goes through
but when I make one definition opaque by ending it with Qed. instead of
Defined. the "Eval compute" hangs.
Isn't it supposed to terminate anyway with whatever expression in a normal
form it ends up with without unfolding the opaque definition?
Vladimir.
- [Coq-Club] strange behavior of "Eval compute", Vladimir Voevodsky
- RE: [Coq-Club] strange behavior of "Eval compute", Georges Gonthier
