coq-club - RE: [Coq-Club] strange behavior of "Eval compute"
chronological Thread
  • To: Vladimir Voevodsky <vladimir AT ias.edu>
  • Cc: Coq Club <coq-club AT inria.fr>
  • Subject: RE: [Coq-Club] strange behavior of "Eval compute"
  • Date: Thu, 28 Oct 2010 22:15:34 -0400 (EDT)
You may also want to try
Eval lazy beta delta iota zeta in ...
which can work well in some situations where you have a big computation that gets thrown away anyways.
On Thu, 28 Oct 2010, Georges Gonthier wrote:
 Evaluation is guaranteed to terminate, but not necessarily in your
lifetime...
If the definition you rendered opaque is a test performed by your recursive
function before the recursive calls, for instance, I would expect the
behaviour you describe: because it is unable to evaluate the test, Eval
unfolds the complete branching tree, which is exponential in the size of the
recursion depth -- and in practice, exponential is pretty much the same thing
as infinite.
 -- Georges
-----Original Message-----
[mailto:vladimir AT ias.edu]
Sent: 28 October 2010 19:26
To: Coq Club
Subject: [Coq-Club] strange behavior of "Eval compute"
Hello,
I am using "Eval compute in ..." to compute a term of type nat which is defined in a
complicated way but should reduce to (S O).  When all the intermediate definitions are made
transparent the computation goes through but when I make one definition opaque by ending it with
Qed. instead of Defined.  the "Eval compute" hangs.
Isn't it supposed to terminate anyway with whatever expression in a normal
form it ends up with without unfolding the opaque definition?
Vladimir.
Russell O'Connor                                      <http://r6.ca/>
``All talk about `theft,''' the general counsel of the American Graphophone
Company wrote, ``is the merest claptrap, for there exists no property in
ideas musical, literary or artistic, except as defined by statute.''
