- To: "coq-club AT inria.fr" <coq-club AT inria.fr>
- Subject: RE: [Coq-Club] Equality-witnessing coercions?
- Date: Tue, 9 Nov 2010 22:45:14 +0000
- Accept-language: en-US
Adam, Guillaume: thanks for the quick responses. This is a nice trick to
learn---thanks!
But, it isn't exactly what I am looking for.
Say I want to write this function (using the same definitions of A, B and foo
as below):
Definition bar (a:A) (b:B a) : (B a * unit) :=
(b, match a with
| One => foo b
| Two => tt
end).
Using the trick, I can transform it like so:
Definition bar2 (a:A) : (B a) -> (B a * unit) :=
match a as a0 return (B a0 -> (B a0 * unit)) with
| One => fun b => (b, foo b)
| Two => fun b => (b, tt)
end.
I really would like to maintain the syntactic structure of bar, and this
trick destroys the structure.
So, any other suggestions?
Thanks!
-Nik
> -----Original Message-----
> From: Adam Chlipala
> [mailto:adam AT chlipala.net]
> Sent: Tuesday, November 09, 2010 2:18 PM
> To: Nikhil Swamy
> Cc:
> Subject: Re: [Coq-Club] Equality-witnessing coercions?
> Nikhil Swamy wrote:
> > The example below illustrates what I'd like to accomplish.
> > Inductive A : Type :=
> > | One : A
> > | Two : A.
> > Inductive B : A -> Type := .
> > Definition foo (b: B One) := tt.
> > Definition bar (a:A) (b:B a) : unit :=
> > match a with
> > | One => foo b (* some way to coerce b's type to (B One)? *)
> > | Two => tt
> > end.
> A simple rearrangement of the function definition gets this to go through.
> What looks like magic actually works because this change makes it possible
> to
> use an inferred [return] clause to express the dependency between [a] and
> [b].
> Definition bar (a:A) : B a -> unit :=
> match a with
> | One => foo
> | Two => fun _ => tt
> end.
> This and other dependent typing "tricks" are one of the main subjects of
> CPDT (http://adam.chlipala.net/cpdt/).
- [Coq-Club] Equality-witnessing coercions?, Nikhil Swamy
- Re: [Coq-Club] Equality-witnessing coercions?,
Adam Chlipala
- RE: [Coq-Club] Equality-witnessing coercions?, Nikhil Swamy
Adam Chlipala
Adam Chlipala
- <Possible follow-ups>
- Re: [Coq-Club] Equality-witnessing coercions?, Guillaume Melquiond
Adam Chlipala
