- To: "coq-club AT inria.fr" <coq-club AT inria.fr>
- Subject: [Coq-Club] The type Type
- Date: Sun, 19 Dec 2010 13:02:09 +0000
Hi,
I have a few questions about the type Type.
1. What is the significance of Top in Type annotations? Is Type (* (0)+1 *) the same as Type (* (Top.0)+1 *)?
Coq < Set Printing Universes.
Coq < Check Set.
Set
: Type (* (0)+1 *)
Coq < Check Type.
Type (* Top.1 *)
: Type (* (Top.1)+1 *)
Coq < Check Type (* (Top.1)+1 *).
Type (* Top.2 *)
: Type (* (Top.2)+1 *)
2. Why does the type of Type change from one query to another?
Coq < Check Type.
Type (* Top.1 *)
Coq < Check Type.
Type (* Top.2 *)
Coq < Check Type.
Type (* Top.3 *)
: Type (* (Top.3)+1 *)
3. What is the type of Type in option_ind?
Coq < Check option_ind.
option_ind
: forall (A : Type (* Coq.Init.Datatypes.20 *)) (P : option A -> Prop),
(forall a : A, P (Some a)) -> P None -> forall o : option A, P o
4. Is there a way of successfully querying (option_ind x) for some x? The unset command doesn't appear to apply here.
Coq < Unset Implicit Arguments.
Coq < Check (option_ind Type).
Toplevel input, characters 18-22:
Error: The term "Type (* Top.9 *)" has type "Type (* (Top.9)+1 *)"
while it is expected to have type "option ?6 -> Prop".
Thanks.
Regards,
Jeff.
- [Coq-Club] The type Type, Jeffrey Terrell
- Re: [Coq-Club] The type Type, Adam Chlipala
