- To: Jeffrey Terrell <jeff AT kc.com>
- Cc: "coq-club AT inria.fr" <coq-club AT inria.fr>
- Subject: Re: [Coq-Club] The type Type
- Date: Sun, 19 Dec 2010 09:35:48 -0500
Jeffrey Terrell wrote:
I have a few questions about the type Type.
1. What is the significance of Top in Type annotations? Is Type (* (0)+1 *) the same as Type (* (Top.0)+1 *)?
I think my answer to this question should also address the next two.
The term [(0)] represents the lowest type universe. Any term of the form [(Module.number)] represents a mutable universe _variable_. That is, the answer to your question is no. Think of the first as a constant and the second as a variable that just happens to contain the constant in its name. Variables can become determined in the process of type checking, which is why you sometimes see types change from one query to another. I believe this _is_ all covered in the Coq manual, though the details of printing type levels may not be.
4. Is there a way of successfully querying (option_ind x) for some x? The unset command doesn't appear to apply here.
Coq < Unset Implicit Arguments.
This command only affects definitions yet to come. You should use one of the notations for referencing identifiers with different implicitness behavior. Either preface the identifier with [@] or use the [(argumentName := term)] notation.
As an alternate presentation of this material, I recommend Chapter 11 of CPDT (http://adam.chlipala.net/cpdt/).
- [Coq-Club] The type Type, Jeffrey Terrell
- Re: [Coq-Club] The type Type, Adam Chlipala
