- To: coq-club AT inria.fr
- Subject: Re: [Coq-Club] Beginner's question: rewrite
- Date: Sat, 25 Dec 2010 23:47:26 -0300
Hi Evgeny,
> (Note that you can just say "rewrite H" instead of "rewrite -> H".) In
> any case, your insight that one can do "rewrite H. apply Em." instead
> of "rewrite <- H in Em. apply Em." is correct.
Thanks for confirming this! at least I'm not so confused ;)
> If you still have this problem, could you create a small standalone
> file and post it? Also, what version of Coq do you have? If you can
> use the command line and if you know where the program coqtop is, you
> can type "coqtop --version" to find out the version.
I have found what seems to be the problem. The SF files do some imports,
which eventually import Basics.v. This file has a definition for plus/+ :
Fixpoint plus (n : nat) (m : nat) {struct n} : nat :=
match n with
| O => m
| S n' => S (plus n' m)
end.
Notation "x + y" := (plus x y) (at level 50, left associativity).
Putting these definitions at the beginning of the following file:
(** imports, or definition of plus/+ **)
Inductive ev : nat -> Prop :=
| ev_0 : ev O
| ev_SS : forall n:nat, ev n -> ev (S (S n)).
Theorem ev_sum : forall n m,
ev n -> ev m -> ev (n+m).
Proof.
intros n m En.
induction En as [|n' En'].
simpl. intro Em. apply Em.
intro Em. apply IHEn' in Em.
assert (H: S (S n') + m = S (S (n' + m))).
simpl. reflexivity.
apply ev_SS in Em.
rewrite H.
(* rewrite <- H in Em. *)
apply Em.
Qed.
fails on the rewrite H with
"Error: Found no subterm matching "S (S n') + m" in the current goal."
If I remove the imports / remove the definition of plus/+, then it works!
So this seems to be a problem with the definition of plus/+. Any idea?
Thanks,
-- Éric
- [Coq-Club] Beginner's question: rewrite, Eric Tanter
- Re: [Coq-Club] Beginner's question: rewrite,
Sidi Ould_biha
Eric Tanter
Evgeny Makarov
- Re: [Coq-Club] Beginner's question: rewrite, Eric Tanter
Eric Tanter
Eric Tanter
- Re: [Coq-Club] Beginner's question: rewrite, Ben Moseley
- Re: [Coq-Club] Beginner's question: rewrite, Alexandre Pilkiewicz
Eric Tanter
Eric Tanter
Evgeny Makarov
Eric Tanter
Sidi Ould_biha
