- To: Eric Tanter <etanter AT dcc.uchile.cl>
- Cc: coq-club AT inria.fr
- Subject: Re: [Coq-Club] Beginner's question: rewrite
- Date: Sun, 26 Dec 2010 10:09:02 +0000
The problem seems to be that the two different usages of '+' in your 'assert'
are getting mapped to different 'plus' implementations.
This can be seen if you use:
Unset Printing Notations.
assert (H: S (S n') + m = S (S (n' + m))).
eq (plus (S (S n')) m) (S (S (Peano.plus n' m)))
Also, if you try these two:
assert (H1: (m + n') = (n' + m)).
assert (H2: S (m + n') = S (n' + m)).
You can see that the former is understood as:
eq (plus m n') (plus n' m)
...but the latter as:
eq (S (Peano.plus m n')) (S (Peano.plus n' m))
I don't know enough about Coq's Scope/Notation mechanism to explain why this
is the case (from "About S." it seems likely it's because the argument of 'S'
is declared to be in 'nat_scope'...), but hopefully the above is useful.
--Ben
On 26 Dec 2010, at 03:06, Eric Tanter wrote:
> On Dec 25, 2010, at 11:59 PM, Eric Tanter wrote:
>> Note that I've just realized that the HTML page for Basics.v in SF:
>> http://www.cis.upenn.edu/~bcpierce/sf/Basics.html
>> defines plus within a Playground2 module in order to not mess up with the
>> actual definition.
>> But the file Basics.v that is distributed does not include these module
>> declarations, so the definition of plus given there does interfere.
> I now realize this has been fixed already online. I was using an older
> version of the files :/
>> At this point, I guess I'm interested in understanding why the definition
>> of plus used in the code below does not work.
> This is still the case!
> Thanks,
> -- Éric
- [Coq-Club] Beginner's question: rewrite, Eric Tanter
- Re: [Coq-Club] Beginner's question: rewrite,
Sidi Ould_biha
Eric Tanter
Evgeny Makarov
Eric Tanter
Eric Tanter
Eric Tanter
- Re: [Coq-Club] Beginner's question: rewrite, Ben Moseley
- Re: [Coq-Club] Beginner's question: rewrite, Alexandre Pilkiewicz
- Re: [Coq-Club] Beginner's question: rewrite, Eric Tanter
Eric Tanter
Eric Tanter
Eric Tanter
Evgeny Makarov
Eric Tanter
Sidi Ould_biha
