coq-club - Re: [Coq-Club] MapsTo in FMapInterface
chronological Thread
  • To: Aaron Bohannon <bohannon AT cis.upenn.edu>
  • Cc: Coq Club <coq-club AT inria.fr>
  • Subject: Re: [Coq-Club] MapsTo in FMapInterface
  • Date: Wed, 09 Feb 2011 15:11:26 -0500
Aaron Bohannon wrote:
I am using FMaps in my development and want to write a tactic that
matches hypotheses of the form (MyMap.MapsTo k v m).  The problem is
that, when I destruct a proposition of the form (MyMap.In k m), I end
up with a hypothesis of the form (MyMap.Raw.PX.MapsTo _ _ _).  A
tactic that matches on (MyMap.MapsTo _ _ _) will not match hypotheses
of the form (MyMap.Raw.PX.MapsTo _ _ _).  Of course, I can write a
tactic that refers directly to MyMap.Raw.PX.MapsTo, but I feel like
this is violating the intended abstraction of the FMap interface.
Unforunately, the tactic "fold MyMap.MapsTo" does not help because
MyMap.MapsTo seems to be defined as an eta-expansion of
MyMap.Raw.PX.MapsTo.  Any other ideas?  Or do I have to write a tactic
that breaks the abstraction?
There's a potentially inefficient version that does:
match goal with
    | [ H : ?f ?a ?b ?c |- _ ] =>
    equate (f a b c) (MyMap.MapsTo a b c); (* use H as planned *)
end.
...for some implementation of an equality check [equate], for instance by [assert]ing that the two terms are equal, making sure [reflexivity] proves it, and then clearing the hypothesis that [assert] added.
(I haven't actually run the above code, so please excuse typos. :])
You may also find that you can ignore this altogether. For instance, if you want to do forward reasoning with a theorem [thm] that takes a fact matching the hypothesis as its first assumption, you may be able to get away with running [apply thm in H] for every hypothesis [H], delegating the matching work to unification.
