- To: Adam Chlipala <adam AT chlipala.net>
- Cc: Coq Club <coq-club AT inria.fr>
- Subject: Re: [Coq-Club] MapsTo in FMapInterface
- Date: Wed, 9 Feb 2011 15:23:19 -0500
- Domainkey-signature: a=rsa-sha1; c=nofws; d=gmail.com; s=gamma; h=mime-version:sender:in-reply-to:references:date :x-google-sender-auth:message-id:subject:from:to:cc:content-type :content-transfer-encoding; b=xtYtkPE32luqRBPFvi8gJ7isjG80wcXTTkq6QC7vEppk5FLgTKdfI5/06e3lppIu0G Sr5LWwaFbZnoC0RgApNeG5HilB4hC129bninnW3eMS6lnqX0oIcpw8lqZXhyltgqLA9m QBl/gvKDkOdpOUFM4igCJnCQ3uHW01xK1B9Lk=
(Oops...I hit send too early.)
I was just going to add that I'm not sure if my "optimization" is
measurably faster, though.
- Aaron
On Wed, Feb 9, 2011 at 3:20 PM, Aaron Bohannon
<bohannon AT cis.upenn.edu>
wrote:
> Thanks for the quick suggestions. Perhaps the purely brute force
> method can be slightly improved like this:
> repeat match goal with
> | k: _ |- _ =>
> progress change MyMap.key in k
> end;
> | k: MyMap.key, v: ?A, m: MyMap.t ?A, H: _ =>
> progress change (MyMay.MapsTo k v m) in H
> end.
> On Wed, Feb 9, 2011 at 3:11 PM, Adam Chlipala
>Â <adam AT chlipala.net>
> wrote:
>> Aaron Bohannon wrote:
>>> I am using FMaps in my development and want to write a tactic that
>>> matches hypotheses of the form (MyMap.MapsTo k v m). The problem is
>>> that, when I destruct a proposition of the form (MyMap.In k m), I end
>>> up with a hypothesis of the form (MyMap.Raw.PX.MapsTo _ _ _). A
>>> tactic that matches on (MyMap.MapsTo _ _ _) will not match hypotheses
>>> of the form (MyMap.Raw.PX.MapsTo _ _ _). Of course, I can write a
>>> tactic that refers directly to MyMap.Raw.PX.MapsTo, but I feel like
>>> this is violating the intended abstraction of the FMap interface.
>>> Unforunately, the tactic "fold MyMap.MapsTo" does not help because
>>> MyMap.MapsTo seems to be defined as an eta-expansion of
>>> MyMap.Raw.PX.MapsTo. Any other ideas? Or do I have to write a tactic
>>> that breaks the abstraction?
>> There's a potentially inefficient version that does:
>> match goal with
>> | [ H : ?f ?a ?b ?c |- _ ] =>
>> equate (f a b c) (MyMap.MapsTo a b c); (* use H as planned *)
>> end.
>> ...for some implementation of an equality check [equate], for instance by
>> [assert]ing that the two terms are equal, making sure [reflexivity] proves
>> it, and then clearing the hypothesis that [assert] added.
>> (I haven't actually run the above code, so please excuse typos. :])
>> You may also find that you can ignore this altogether. For instance, if
>> you
>> want to do forward reasoning with a theorem [thm] that takes a fact
>> matching
>> the hypothesis as its first assumption, you may be able to get away with
>> running [apply thm in H] for every hypothesis [H], delegating the matching
>> work to unification.
- [Coq-Club] MapsTo in FMapInterface, Aaron Bohannon
- Re: [Coq-Club] MapsTo in FMapInterface,
Adam Chlipala
Aaron Bohannon
- Re: [Coq-Club] MapsTo in FMapInterface, Aaron Bohannon
- Re: [Coq-Club] MapsTo in FMapInterface, Stéphane Lescuyer
Aaron Bohannon
Adam Chlipala
