- To: Coq Club <coq-club AT inria.fr>
- Subject: [Coq-Club] apply, auto, and implicit type classes
- Date: Mon, 14 Feb 2011 19:22:33 -0500
- Domainkey-signature: a=rsa-sha1; c=nofws; d=gmail.com; s=gamma; h=mime-version:sender:date:x-google-sender-auth:message-id:subject :from:to:content-type; b=sFNHsleTA+7qUNo15VOekcjHNIwVd1P5gwm3trU8LBxffKZWqCmLHP/5ZfphQRigBL 2Svh37+hMfkZYtV4baLn4Samiz/rf5ituUMQBFSMk588bV22CTvwwvumjV8apxhtW1PA CQI9/eOLKUfFrIjh+OacXNSlZaDHC890V315M=
Hi,
I have found a strange behavior. Consider this custom tactic:
Tactic Notation "foo" constr(e) constr(e1) :=
apply e with (1 := e1).
I have a proof state in which "apply lemma with (1 := H)" succeeds as
expected; however "foo lemma H" fails.
The problem revolves around type classes. "lemma" is parametric in a
type and its typeclass dictionary/proof object (and these arguments
are implicit). Writing the "apply" tactic inline seems to use the
goal to figure out how to instantiate these implicit arguments.
However, when used in a tactic definition, "apply" seems to just
choose an arbitrary instantiation for the implicit arguments, which in
most cases will not match the goal.
Is this a bug or is it the "expected" behavior?
Actually, this is likely related to typeclass instantiation issues
that come up with "auto", too (and maybe there is a general principle
at work): "Hint Resolve lemma." seems to be basically useless when
"lemma" has implicit typeclass arguments. I have found two
workarounds:
1) You can write "Hint Extern ... => apply lemma."
2) You can write "Hint Resolve @lemma." And in addition, add something
like "Hint Extern 1 (MyTypeClass _) => auto using
typeclass_instances." (assuming "lemma" is generic for MyTypeClass).
Now I am wondering which is more "correct". Although solution (1) has
been working for me, I am now suspicious about that approach, given
the problem I've run into with my tactic definition above.
- Aaron
- [Coq-Club] apply, auto, and implicit type classes, Aaron Bohannon
- Re: [Coq-Club] apply, auto, and implicit type classes,
Tom Prince
- Re: [Coq-Club] apply, auto, and implicit type classes, Aaron Bohannon
Tom Prince
